72 wiper door opening problem - NCRS Discussion Boards
  • casper
    Trying to find a shortcut instead of checking whole system. When I turn the wipers on with wiper switch,the door will not open until you pull the override switch under the dash. Is the problem the vacuum switch on the speedo, or the door switch in the cowl?
  • Thad L.
    • April 30, 1999
    • 168
    Re: 72 wiper door opening problem
    I think it's the switch behind the tach! Thad Also listen for the click of the relay in the tunnel when you use the wiper switch!!
