C2 67 Battery - NCRS Discussion Boards
C2 67 Battery
  • Stephen L.
    • May 31, 1984
    • 3158
    C2 67 Battery
    Anybody know how large the date code letters are for the battery which are stamped in the top??
  • Joe R.
    • March 1, 2002
    • 1356
    Re: C2 67 Battery
    Hi Steve:
    I have a battery from Restoration Battery that was dated 7CV as shown in the photo below. When I questioned the appearance of the date code, I was told that the characters were actually burned into the molded rubber casing by heating them first, per the original factory process.
    In any event, I think the characters in the tool are nominally about 0.200 inches tall, but the height increases a bit due to the way they are impressed on the casing.
    • Stephen L.
      • May 31, 1984
      • 3158
      Re: C2 67 Battery
      Thanks for the photo. It appears the characters are adjacent to a couple of filler caps. Correct?
      • Joe R.
        • March 1, 2002
        • 1356
        Re: C2 67 Battery
        Yes, that is correct. There is also a second stamping that I believe is supposed to be the day of the month. That, too, is near the caps, but a few inches away from other date stamping. In my case the second stamping is the digit "9," barely visible near the Delco Eye cap in the photo below.
        • Stephen L.
          • May 31, 1984
          • 3158
          C2 67 Battery Thanks for the info *NM*
