C1Rear Wheel Bearing Retainers - NCRS Discussion Boards
  • Eric Eade
    Can someone tell me the correct finish for the retainers - mine show their age and some surface rust but appear to be unpainted and unplated. Also, Para--n shows an exploded assembly in their catalog that the retainers are fastened by bolts coming from the center of the chassis out to the wheel. The retainers that I removed from my car have the four square head bolts pressed into the retainer plate and fastened with nuts toward the strut rod mount on axle housing. Thanks, Eric 31337
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1Rear Wheel Bearing Retainers
    (The retainers that I removed from my car have the four square head bolts pressed into the retainer plate and fastened with nuts toward the strut rod mount on axle housing.)
    Your's are correct and painted black
    • Eric Eade
      Thanks Roy, it's tough to tell on a few of these items what's right and what's not. Eric
      • Roy B.
        • February 1, 1975
        • 7044
        Too many people take simple things and make them a big deal.
        • Eric Eade
          You got that right! ;-) thanks. *NM*
