c2 TI amp install is the AIM correct on hole locat *NM* - NCRS Discussion Boards
  • Phil P.
    • April 1, 2006
    • 409
  • Rob A.
    • December 1, 1991
    • 2126
    Re: c2 TI amp install is the AIM correct on hole l
    Phil,
    I found it to be correct on my '67 big block.
    • Loren L.
      • April 30, 1976
      • 4104
      What AIM are we talking about? If
      it i '65, it is NOT correct for my late car.
      • Phil P.
        • April 1, 2006
        • 409
        67 AIM K66 REF A2 page 316
        the "existng" hole for locating the drilling of the other three holes,(for amp mount), looks to be the hole for the "harness" clamp for the turn signal harness---if i'm reading the AIM correctly---the AIM shows the stand alone hole,(outboard), to be 1" inboard off of the "exsiting" hole---if this is used the lower outboard portion of the amp. would cover part of the larger hole that the turn signal harness goes through---this has to be something simple that has plum eluded my simple brain---i'm looking at the fiberglass portion of the fender not the metal core support---thanks,phil
        • Phil P.
          • April 1, 2006
          • 409
          67 AIM (sorry) *NM*
          • Phil P.
            • April 1, 2006
            • 409
            can some one post a picture of a 67 ti amp instal *NM*
              Re: 67 AIM K66 REF A2 page 316
              Phil -
              The "existing hole" is the large hole for the parking lamp harness grommet.
              • Phil P.
                • April 1, 2006
                • 409
                thanks john *NM*
