Any suggestions who to use for Horn Rebuild? - NCRS Discussion Boards
  • Steve Wallach
    I'm looking to get my Mid Year horns rebuilt, any suggestions who to use?
    Steve
  • Terry F.
    • September 30, 1992
    • 2061
    Re: Any suggestions who to use for Horn Rebuild?
    You could probably do it yourself?? Terry
    • Steve Wallach
      Thought about it, but I've never done the horns, have you?
      Is it relatively easy to achieve a good result?
      Steve
      • Terry F.
        • 2061
        I have not done them but I read the most recent restorer and it looks simple. I wouldn't hesitate to try one. I have a few ideas on how to work out the rivet issues, etc. Terry
        • Steve Wallach
          I read that also, which probably got me thinking about this project. The steel rivits and proper patern kind of intimidate me....
          Steve
          • Louis F.
            • September 30, 1991
            • 132
            Steve, I just got a set back to weeks ago.I used Gary at Horn Works, does great work and has a fast turnaround. Highly recomended, Lou
            • John S.
              • September 30, 1997
              • 263
              The Horn Works did my 1965 horns. His workmanship is excellent and a quick turnaround.
              • Norm C.
                • April 1, 1989
                • 227
                Do Archives Search...Ron Goralski...
                This subject was recently discussed.... Ron was recommended by several... Depends on what you are looking for.... I was told Ron's refurbish will have zero points deduction.... If that's not a huge issue for you... then there are several others. I am very pleased with mine!
                • Rick S.
                  • January 1, 2003
                  • 1203
                  Re: Do Archives Search...Ron Goralski...
                  I had Ron Goralski do my horns in Dec 05 and have been very pleased. His turnaround time, given the Christmas holiday, was very good. Rick
                  • Patrick T.
                    • September 30, 1999
                    • 1286
                    Any suggestions for a Horn Rebuild?
                    I had the Horn Works rebuild mine; they look and sound great. It took 10 days and the price was very reasonable. I don't believe Ron Goralski is still in business. PT
                    • Ian S.
                      • June 30, 2002
                      • 264
                      Re: Any suggestions for a Horn Rebuild?
                      Ron is still in business and the work he did for me was fantastic. Nice guy too.
                      Ian
                      • Terry F.
                        • 2061
                        Hmmm. I would like to try it. If you had a vise and a drill press, you would be home free and a dremel tool. It looks like you have a lot of feedback. I believe there are a couple people that are rebuilding them. Sounds like they do nice work. Terry
                        • Norm C.
                          • April 1, 1989
                          • 227
                          Remember Rivets...
                          Again, if points is part of your consideration, the casing is rivited... you need to have a set up that you can acurately press the rivets without cracking the plastic casing... Good Luck. BTW.... I did mine with Ron Goralski this summer,,, turn around was fast..... You gotta believe in a vendor who will send the part back to you with an invoice. First time I have'nt been asked to prepay. Now there's a guy who believes in his work!! Sounds and looks GREAT!!
                          • Steve Wallach
                            I got ahold of Ron Goralski, and I sent my horns off yesterday. A lot of people have recomended him so I thought I would give him a try. He did say he is doing quite a few horns right now, so he's a little back logged, but I'm not in too much of a hurry anyway.
                            Thanks for all the input!
                            Steve
                            • Paul O.
                              • August 31, 1990
                              • 1716
                              Steve check with Joe Perri in Chicago does great work 312-307-1977 also does radiator caps restorations. Paul
