AC spark plug suffixes decode - NCRS Discussion Boards
+ More Options
Posts
  • Charles P.
    • April 30, 2005
    • 332
    Last week there was a good thread about spark plug heat ranges and number decoding. (4 is thread size, second number heat range) My question is what do the the letters after the numbers mean. I see R45T, R45TS, R45SX, R45NX etc. If an R45 ACNITER is recommended on a base engine 72 or 73 what would the correct suffix be?
    • 43258
    Re: AC spark plug suffixes decode
    Charles-----
    The suffix refers to the seat style and tip style. Earlier plug models (like the R-45) did not use a suffix code since all were gasketed type. A "T" suffix refers to a tapered seat (i.e. "peanut" plug). The "S" refers to extended tip.
    • Charles P.
      • April 30, 2005
      • 332
      If R45 is the plug best suited would T or tapered be best or correct?
        Charles -
        If your '72-'73 has the original cylinder heads, they're machined for the tapered "peanut" plugs ("T" suffix).
