90 ZR1 injectors - NCRS Discussion Boards
90 ZR1 injectors
  • Charles A.
    • July 31, 1980
    • 180
    90 ZR1 injectors
    Bought a 90 ZR1 that sat for 6 years. Checked all other systems, changed fluids and isolated problem to bad injectors(shellac probably). Anyway instead of trying to clean just want to buy new ones. What is best source and price?
  • John daly
    Re: 90 ZR1 injectors
    chuck,
    For the 1990 LT5,I see GM part number 17069647 injector kit- primary list price $168.22, and part number 17066648- injector kit secondary at list price $144.44
    Your local GM dealer may discount, best to shop around.
    • Charles A.
      • July 31, 1980
      • 180
      John thanks.Have a better price but still alot for 16 injectors. Looking for someplace that sells a set of primary and secondaries.
        • 43222
        chuck----
        I don't know of a source that sells these things by the set. However, that doesn't mean that there isn't one.
        As John mentions, the primary injectors are GM #17069647 and the secondary injectors GM #17069648. These are also known as Delco #217-256 and 217-257, respectively. A "rock bottom" Delco parts system price on these is going to be about $80/each for the primary injectors and about $67/each for the secondaries. Total price for the 16 needed for the car set is then going to be about $1200 for the set.
        If you are comfortable with it, you can do a lot better by going with remanufactured injectors. I'd be a bit "leery" about using them, but there is a huge cost savings. You can get remanufactured injectors for about $30/each net after core return. So, in this case, a set would cost you about $500.
        • Charles A.
          • July 31, 1980
          • 180
          Joe thanks 1200 is about 300 better than my local source. Could you let me know where I can get at that price?
            • 43222
            Chuck---
            You have mail.
            • Charles A.
              • July 31, 1980
              • 180
              Thanks Joe in the process of ordering now.
