PF 1218 Oil Filter - NCRS Discussion Boards
PF 1218 Oil Filter
  • Randy S.
    • January 1, 2003
    • 586
    PF 1218 Oil Filter
    Well time for an oil change on my 66 SB. Add 1 more to Duke's Shell Rotella CL-4 converts.
    I thought I 'd opt for the AC Delco PF 1218 as I read here it was a full quart capacity and I would keep my car "all GM". I suspect Delphi doesn't make these any more but I was surprised it was only 4 1/2 " long. It did not even have a silk screened label, just a cheapo stick-on paper label on a generic blue can. Where else did the supplier cut corners?
    Back to Napa.
    Randy
  • Clem Z.
    • January 1, 2006
    • 9427
    i think PF35L filters are still available
    and they are the long ones like the orignal PF35s. they are synthenic media and are expensive
    • Phil P.
      • April 1, 2006
      • 409
      Re: PF 1218 Oil Filter
      the 1218 use to be long went short about a year ago---if you want the same blue and want to peel the sticker get the stp9100s full quart---checked valved for 4X4 nice heavy filter will work just fine
        • 15674
        I don't recommed Shell Rotella. I recommend API CI-4 or CI-4 Plus.
        Rotella is just one of MANY brands.
