Oil filter cross reference help - NCRS Discussion Boards
  • Gary Schisler
    I have a Puralator L20033 oil filter that I cannot for the life of me remember which car is goes to. Does anyone have a parts book with an oil filter cross reference? I have four cars that I own plus two others in extended family that I maintain. The local FLAP doesn't seem to be able to cross reference this for me.
    Thanks in advance.
    Gary
    • 15674
    Re: Oil filter cross reference help
    My Fram catalog crosses it to a PH25 - 13/16"-16 straight thread. Lots of applications including GM and AMC. Interchangeable with AC PF-24 and PF-30.
    Try the Web. Most manufacturers have online catalogs, cross-references, and buyer's guides (technical data and applications) now, and they are getting better all the time.
    The Web is making paper catalogs obsolete.
    • Gary Schisler
      Thanks Duke
      That makes it an equivalent to one that will should fit my 72 LT1. I thought that the size and shape looked too big for anything else that I might use it on.
      Gary
        • 43221
        Re: Thanks Duke
        Gary----
        No, it will not work for a 72 LT-1 (or any other Chevrolet small block or big block gasoline engine). The L20033 is equivalent to the PF-24. The PF-24 has many applications but, primarily, it was used for old AMC, Buick and Pontiac V-8 engine applications.
        While the configuration of this filter LOOKS like a PF-25, it will not interchange. I believe that the threads are different, among other things.
          • 11643
          Re: Thanks Duke
          The PF-24 is also applicable to Oldsmobile, particularly the 1970 350 cid engine if nothing else.
          Patrick
          • Alan D.
            • August 31, 2000
            • 111
            Joe is right about a PF-24 filter not being used in place of a PF-25 filter. I have experience with this. I bought a PF-25 filter and did not realize that it a PF-24 filter was in the box instead.
            I started the car and backed out of the garage and noticed a big puddle of oil on the floor. Yep, the PF-24 leaked like crazy.
            Al Dieterle
            • Phil P.
              • April 1, 2006
              • 409
              i think the gasket is inboard "L20033" vs the perimeter "PF25"---threads the same---since the a/c 2018 has switched to a shorter filter i have gone with an stp9100s---4x4 style "check valve" for reverse flow filter that is as tall as the older 2018 or if you will the pf35 for more capacity and filter element area
              • Gary Schisler
                Aha! Mystery solved?
                I sold a 77 Buick Electra 225 two years ago. I would guess that this is a leftover. Regardless, I will trash this filter since no other application currently sits in my garage or driveway.
                Thanks to all of you who responded.
                Gary
