1975 AC set up help - NCRS Discussion Boards
1975 AC set up help
  • Joseph K.
    • March 1, 1980
    • 168
    1975 AC set up help
    Greetings all: I have a 1975 corvette coupe that has had the AC removed and the core plugged. What I need is for some one who has this setup out of their car to take some clear photos of the complete setup for me. The diagrams that the books have do not help much. I anyone can help me before I start to collect parts I would be very thankful. Photos of any parts will be helpful as well as any shots of working setups, I plan to go junking this weekend......TIA..Joe
  • Lee S.
    • September 30, 2002
    • 156
    Re: 1975 AC set up help
    I have a 74 big block and have some photos. What area do you want?
    • Joseph K.
      • March 1, 1980
      • 168
      Lee: I have a small block but if the components are the same, and the area which they are located are the same then shots of the passenger/drivers side setup is what I am looking for. Clear shots of the mounting brackets and ect would be great............thanks in advance.............Joe
      • Lee S.
        • 156
        There are lots of areas to consider. Condenser mounting? Compressor Mounting? VIR? etc. Try to be more specific. You may want to take a look at images at Corvette Central's web site ( http://www.corvettecentral.com ). Just go to 69 - 82 and type in AC Compressor. You will see several illustrations with parts break downs. I'm glad to help you out but it may be a couple weeks before I can provide specific pictures of my car. I'm having back surgery on Wednesday and will be out of commission for a while.
        Daftar dan mainkan slot gacor dengan RTP tertinggi hari ini. VIPTOTO, situs terpercaya untuk cuan besar dari slot online!
