C2 427 Carb - 3811 - NCRS Discussion Boards
C2 427 Carb - 3811
  • Phil B.
    • Today
    C2 427 Carb - 3811
    A friend has the opportunity to purchase a cast iron intake and carb from a 1966 390 Horse Corvette. Intake number 3866948 and carb 3811. The carb has the part number and model number on it, but no date code. The seller claims it to be original and not a service replacement. Is this correct (no date code) for an original carb?
  • Steve Wallach
    Re: C2 427 Carb - 3811
    my 67 (3811) has a date code...
    cheers,
    Steve
    • Clem Z.
      • January 1, 2006
      • 9427
      holley made a batch of corvette carbs
      without any date codes for certain carb sellers. so i have been told.
      • Kent D.
        • February 1, 1992
        • 100
        The carb for a 390 hp '66 is a 3370.
          The 3811 carb was used on the '67 L-36.
          • Phil B.
            • Today
            Thanks for the info. Intake has 66 date so it may be a 1967 intake and carb. Not sure of date code since a friend is looking at it. Original question is still should the carb have a date stamp if it is the original carb?
            • John R.
              • September 30, 1999
              • 288
              I have an August 1966 dated 3811 on my 67 L36. Car was assembled in late October of 1966.
                Eric -
                Yes, it should have a 3-digit date code if it's an original production-line carburetor.
                • Richard S.
                  • November 1, 1994
                  • 809
                  John,
                  Do you know if the 67 L36 carb is any better than the 66 3370 it replaced.....thanks.
                  • Bill Stephenson
                    Rick,,,In my opinion (not worth a bunch) the 67 carb is not as good as the 66. I believe that the 67 has no external float-bowl adjustment. You have to take the bowl off and bend the arm. 66 had adjustable floats. I have always thought that it was a cheaper carb, not better. Others more knowledgeable than me may feel differently............Bill S
