1972 and 1977 - NCRS Discussion Boards
1972 and 1977
  • Jerome E Pederson
    1972 and 1977
    Are the wheel trim ring and center hubcap identical for both a 1972 and 1977 Corvette?
    Re: 1972 and 1977
    Center cap, yes; trim ring, no. There's an early vs. late design of the trim ring and the difference deals with where the four clips are mounted with respect to the valve stem hole. Your copies of the respective Judging Guide books should tell you which version goes with which car...the two versions have the clips offset by 90-degrees....
    • Jerome E Pederson
      Re: 1972 and 1977
      Thanks alot Jack. I am looking to buy the trim rings for a 1972 Vette. I have now found a set the seller claims are for 1968 to 1972. Do you know if the trim rings are the same for these years? I do not have the JD books. Could you help me out as to what I should be looking for. Thanks Again.
      Jerry
      • Harmon C.
        • August 31, 1994
        • 3228
        Re: 1972 and 1977
        Jerry
        One of the four sets of clips should be located very close to the valve stem hole for your 72. Later years they were random in location.
        Lyle
        Lyle
        • Phil P.
          • April 1, 2006
          • 409
          Re: 1972 and 1977
          my 72 has the clips clocked almost exactly on the valve stem opening the rest are every 90 degres's (sp) almost exact---hope this helps
