Muncie ID tag - NCRS Discussion Boards
Muncie ID tag
  • don izzo
    Muncie ID tag
    Can someone tell me what the "tin" ID tag with raised number code (found under one of the bolt heads that holds the side cover on) is for. I just saw a few on E-bay in the $40-$50 price range and was wondering why they may be so important to a restoration as to garner such a price. Thanks!
    Don
  • Mike E.
    • February 28, 1975
    • 5138
    Re: Muncie ID tag
    It identifies the transmission by its 7-digit GM part number. By that, you can tell if it is an M-20, 21, or 22. Why does it have value? Because every one of those cars had one of those when it left St. Louis, so it is part of the restorer's desire to return the car to how it was originally configured. There are those who build cars to score points, and there are those who build cars to be as correct as possible for the sake of being as correct as possible--the latter is attracted to a tag like that.
    • Alan Drake
      Re: Muncie ID tag
      They are available from most restoration suppliers for $30 - just specify what year and HP. Not sure why the higher price unless the repro's are not exact?
      Hope somebody enlightens us a bit more!
      • Chuck S.
        • April 1, 1992
        • 4668
        Re: Muncie ID tag
        Mike Ernst has the right answer regarding the cost and desirability. Mike's comments are to be taken in the context that the tag is not judged in the NCRS...Why bother? He explains the "why" quite well.
        I might add that if you don't have one, OR...if it's not in the same position the factory put it, you should know that Bubba has fingered your transmission somewhere along the way. If it's there, in its original position, you can pretty much be assured your transmission has never been touched...a pristine virgin so to speak.
          Add-on
          While NCRS doesn't judge the tag, there are other factory concours judging organizations that do crawl under the car and attempt to verify transmission specifics...
          • Dick W.
            • 10483
            Re: Add-on
            Jack, can you imagine me trying to crawl under a car, while it is on the judging field, to get the tag #. I can think of a few more of us that would have a problem doing this also.
            Dick Whittington
            • Chuck S.
              • April 1, 1992
              • 4668
              Shoot, Dickie, I Can't Picture You...
              Even getting down to all fours!!!
              That other organization must have a really young, athletic judging corps, or they must do that transmission tag thing on a lift.
