71 BB Motor Mounts - NCRS Discussion Boards
71 BB Motor Mounts
  • Sheldon S.
    • March 1, 1999
    • 476
    71 BB Motor Mounts
    Could someone tell me what is the corect head marking on the motor mount bolts that hold the mounts to the frame. I come up with both a F head mark or a A head mark. Is there a correct one? Also where can you buy the left hand alluminum heat shield for the motor mount?
    Thanks in advance.
    Sheldon
    • 43221
    Re: 71 BB Motor Mounts
    Sheldon-----
    I've seen "C" and "A" on the long motor mount bolts. There may well have been others, too. Can you imagine how many of these bolts that GM was using during the period? I don't know if these bolt head markings are judged, anyway.
    The motor mount heat shields are available in reproduction from Dr. Rebuild and, likely, others.
