Ignition switch capacitor or radio capcitor 68. - NCRS Discussion Boards
  • Terry F.
    • September 30, 1992
    • 2061
    Hi, my assembly manual shows part number 1970751 radio capitor as attached to the back of the tachometer housing and then pig-tailed into the wiring harness. But what I found on my 68 was another beasty that is also 0.5MF but different physically. I also believe it to be original/correct for my car. It has the part number 3844184 ink stamped into it. Any opinions on proper application would be greatly appreciated. I can provide a picture if desired. Thanks, Terry
    • 43205
    Re: Ignition switch capacitor or radio capcitor 68
    Terry------
    GM #1970751 and GM #3844184 are, respectively, Delco and Chevrolet part numbers for functionally equivalent capacitors. I see no reason why they could not have been used interchangeably on the assembly line.
    The GM #1970751 was once available in SERVICE. I can find no indication that the GM #3844184 was ever available in SERVICE, so it was a PRODUCTION-only item. Consequently, it seems VERY, VERY unlikley to me that such a part could have found a home on your car unless it was originally installed there.
    • Terry F.
      • 2061
      Good morning Joe! Thank you for the information. Best regards, Terry
