2007 C6 clutch problem - NCRS Discussion Boards
  • LJBottrel
    We just bought a 2007 C6 in August - only 117 miles that we have put on it. This weekend, the clutch blew - couldn't shift out of neutral if car was running, when starting, car bucked even with clutch depressed, when I finally got around the block to get back to my driveway - couldn't get out of first. Any thoughts? Anyone have the same or similar problem?
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: 2007 C6 clutch problem
    There have been a lot of C6 clutch problems, but it's usually about tricky and unpredictable engagement For cars with some time and miles on them, like the 2005s, clutch actuation failure is sometimes related to fluid that's deteriorated from the heat of the exhaust system. In your case, you just got a bad one in my opinion...it happens. It's likely something in the hydraulic system...maybe a bad slave cylinder or air leaking into the system.
    The NCRS Tech Board only covers Corvettes at least 20 years old. For more on C6 clutch problems, you might try Corvette Forum.com, C6 General Forum. They have a search feature, and there are a ton of anguished threads in the archives on clutch problems.
    • Clem Z.
      • January 1, 2006
      • 9427
      sounds like it needs bled since it is a hyd
      clutch.the dealer should be able to handle this.
      • LJBottrel
        Thanks - the dealer picked up my baby today - thanks for the tip on CorvetteForum.com
        LJB
