Hey guys!
This one really has me scratching my head. The core support in my 65 was a later GM service replacement (FI hole), so I needed to replace it with a correct support. A couple of years ago I obtained an NOS core support. It has the saddle brackets on the rods unlike the repos, so I assumed it was the real deal. When I went to install it, it sat way too high. I removed the entire shim stack from both sides, a total of 13 shims. In order to get the side holes to line up, it required no shims on one side, only one on the other. So I cleaned up one of the originals and welded it back into place.
I assume the shims were used to account for variations in the body, and the core supports would be dimensionally identical. The GM replacement support fit fine with the factory shim count, and obviously the original would have fit as well. If it was a repo support, I could understand the difference, but I would think all GM supports would be interchangeable. I've never seen a C2 without at least a few shims on each side. Will this cause a problem during judging? Do I just draw a circle for the shim mark to indicate no shims?
Thanks!
Thanks!
