Hi Guys,
Some of you might recall a number of posts from me a couple of months back reagrding my 1963 engine. This was a fresh and complete rebuild on a restoration block.. My buddy did the assembly (against my better judgement..). The engine was producing oil smoke out of the right hand cylinder bank from the get go and I was looking for suggestions... We had the heads checked and the intake manifold checked, etc. to no avail.. the puppy still smoked (a lot), just from the right side.
I wound up pulling the engine (nothing like doing work twice) and sent it back to the machine shop for tear down and evaluation. The results totally blew me away!
Upon pulling then engine apart, they found that one of the camshaft lobes was almost ground round; i.e the lobe was almost gone!!! The corresponding lifter had a groove in it almost a 1/4 inch deep!! There was a ton of metal particals floating around in the oil which wound up scoring just about everything. Oil rings on two of the right hand cylinders were essentially frozen which accounted for the oil smoke, but strangely enough, the worn camshaft lobe was for #1 cylinder on the left side!!!
The machine shop spent a ton of time (not to mention my money) straightening things out... re-honed cylinder walls, two new pistons, new rings, new bearings, new cam and lifters, crankshaft cut and polished, heads disassembled and cleaned, etc. etc. etc. Included in this mess were 8 new push rods, the originals were slightly bent.
The shop did the reassembly this time around and did the break-in work on their dyno set up.... ran it for a couple of hours... I picked the engine up this past Friday and am getting ready to put my 1963 back together, finally!
I guess there are a couple of lessons here, and some things are better off left unsaid...
I figured that I would share this story just in case anyone finds themselves in a similar situation....
Thanks again to all of you who offered up advice and suggestions throughout this entire situation.. I look forward to finally getting my 1963 back together and on the road!!
