C1 1961 Brake Drums - NCRS Discussion Boards
C1 1961 Brake Drums
  • Richard P.
    • May 31, 2002
    • 190
    C1 1961 Brake Drums
    The brake drum casting numbers on my 61 are GM 3752623 3. I suspect that this is not original or correct. What did they come off and what are the correct numbers for my application? Also, are the front and rear and left and right all identical? Thanks.
    • 43240
    Re: C1 1961 Brake Drums
    Richard------
    GM casting #3752623 are exactly the castings for the brake drums that I would expect to find on a 1961 Corvette with standard brakes and original brake drums. Of course, I can't say whether the ones you have are originals or replacements since the same casting was used for SERVICE brake drums for quite awhile thereafter. Nevertheless, I believe that the casting number is correct for your car. Other castings MAY also have been used.
    All 4 brake drums for a 1961 Corvette with standard brakes were the same.
    • Christopher R.
      • March 31, 1975
      • 1599
      Joe, Weren't the factory front drums rivetted to the hub? Not sure.
        • 43240
        chris------
        I really don't know, I don't recall that feature, but it's possible. In any event, whether they were or not would not affect the casting number for the drums one way or the other.
        • Roy B.
          • February 1, 1975
          • 7044
          Re: C1 1961 Brake Drums chris YES *NM*
