'67 HOOD PANEL SEPARATION - NCRS Discussion Boards
  • David K.
    • September 30, 1992
    • 281
    My hood outer panel has separated from the inner frame at 'two joint' sections on the passenger side. The result is a little flex when I polish & wax the hood in that particular area. Can I leave it as is, or should it be re-glued?? I would prefer not touching the car since it's fully restored. Thanks!
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: '67 HOOD PANEL SEPARATION
    Your choice. I would reglue or bond. This can be done without damaging anything.
    • David K.
      • 281
      Thanks Wayne. If I wish to tackle it myself, how do I re-glue. What product should I use? Can I simply apply the glue from the outer edges of the bonding joint area? Thanks; David
      • Kent K.
        • December 1, 1982
        • 1139
        David,
        Check the recent archives, say in the past 2 months, or so. You should find answers to all your questions. Have fun . . . sounds like a really nice car.
        Regards, Kent #6201
        Kent
        NCM Founder - Member #718
        • Gerard F.
          • June 30, 2004
          • 3805
          Roof and Flashing Sealant
          David,
          Take a look at this thread:
          Jerry Fuccillo
          #42179
          Jerry Fuccillo
          • Mark S. Lovejoy
            David,
            DO NOT use bonding adhesive for this repair. Bonding adhesive gets very hot while curing and will blister the paint on the top (finished) side of the hood.
            Hope this helps.
            Mark
