Dealer number - NCRS Discussion Boards
Dealer number
  • Rick R.
    Infrequent User
    • October 22, 2006
    • 5
    Dealer number
    In restoring a 1965 bb convert.we found the build sheet under the rear carpet. the Zone is 45 the dealer is 239. The data base does not show this dealer. Anyone have an idea of who that dealer was. Thanks, Rick
  • Chuck G.
    • May 31, 1982
    • 2034
    Re: Dealer number
    Zone 45 was the South Bend, Indiana zone. Chuck
    • Philip C.
      • December 1, 1984
      • 1117
      Re: Dealer number Could you share!!!!
      Hi Rick great find could you share the sheet with us!!!!! Thanks Phil 8063
      • Rick R.
        Infrequent User
        • October 22, 2006
        • 5
        This is a high resolution scan of the build sheet. I will post a high resolution picture as soon as I can. At the bottom you will note this was the Dealer copy. It is in perfect condition. The carbon paper tag is still attached on the left. The owner did not realise what this was and almost threw it away. Thank goodness he kept it. Rick
        • Stephen L.
          • May 31, 1984
          • 3158
          This sheet also shows the key codes, engine build code and differential codes as well as the VIN#. It was meant for the dealer records for warranty work and key replacement. Great find.
          • Chuck S.
            • June 30, 1991
            • 184
            Hi Rick;
            GREAT find and thanks for sharing. What is the approximate build date of your `65?? Mine was built the last day of production and I`m thinking I should check that location just in case.......
            • Stephen L.
              • May 31, 1984
              • 3158
              His actual build date, the date the car was completed, appears in the lower left corner of the build sheet. Looks like 6-8-65 or possibly 6-6-65. The date, as well as the engine date, Diff code and key codes were typed onto a copy of the build sheet at the completion of assy.
              • Harry Sadlock
                Re: Dealer number
                Rick, as I recall this is not the build sheet. In earlier years it was call the "Regular Commercial and Truck" document. The name was changed to Corvette. It is just as good if not better than the build sheet as it is the Holy Grail of birth certificates.
                This is the copy that went to the dealer, copy 5, with the driver of the car carrier/truck. These were normally trashed when the car got to the dealer. Either the truck driver or the dealer stuffed it in the car, very lucky on your part. If this is truly a real document you just added, I believe, lots of $$$$$ to the value of the car as it proves what the original engine was/is.
                In the upper left corner under IDENT number is 921496. This is the number that goes on your Window Sticker in the upper right hand corner under the blue Bow tie.
                Harry
                • Harry Sadlock
                  Re: Dealer number
                  Also, the FA on the line with the keys shows it was 396 with 3.70 posi.
                  Harry
