64 Assembly Line - Saving the Best for Last - NCRS Discussion Boards
  • Mark J.
    • March 1, 1996
    • 254
    During a recent foray into a local antique store I ran across several Corvette photos in the automotove memorabillia section. I favor this one as it shows how simple and the assembly process was as compared to the modern line in Bowling Green. I wonder what got installed next?
    P.S.: Regarding the Bowling Green tour, you know how they pick one of the tourists to start the Corvette at the end of the line? How come it's always the cute blonde behind me??
  • Michael H.
    • January 29, 2008
    • 7477
    Re: 64 Assembly Line - Saving the Best for Last
    Interesting that the door trim panel is installed before the body is on the chassis. This pic also must be the Smith plant? I don't think it was done this way at St Louis.
    • Mark J.
      • March 1, 1996
      • 254
      The Dreaded Red X
      My server says I exceeded the data transfer limit. I suspect the photo will reappear later...
      • Mark J.
        • March 1, 1996
        • 254
        I am guessing that perhaps this photo was taken the same time as the bake room photo posted yesterday, which was presumed NOT to be at St. Louis.
        • Michael H.
          • January 29, 2008
          • 7477
          Re: The Dreaded Red X
          I still have the photo Mark. If it doesn't reappear, I'll host and post it for you.
          • Anthony F.
            • December 1, 1985
            • 191
            Mark,
            No picture came up for me. I would really like to see this one, as the bodies in St. Louis DID NOT have door panels prior to the Chassis Mounting, like Michael stated. The AO Smith units did I believe come in with them on due to the window adjustments and water sealing prior to shipping them to St Louis.
            A fella was assigned to a job in the basement to prepare the AO Smith units before the came up stairs to the Trim Line. I would like to be asking him right now just what was there and what he removed from the unit for processing. I do not think that the door panels would have been a problem running through the system except for damage to them.
            Somewhere in the back of my mind I am leaning to door panel removal and reinstallation in Final Trim but I am not sure.
            • Mark J.
              • March 1, 1996
              • 254
              Michael,
              Feel free to repost it at will. I enjoy the discussion surrounding it. Mine will probably reappear tomorrow.
              Mark
              • Michael H.
                • January 29, 2008
                • 7477
                Mark's Assy Line Pic *NM*
                • Michael H.
                  • January 29, 2008
                  • 7477
                  The Wall....And Quiz....
                  Tony,
                  I agree, I believe the St. Louis bodies didn't receive their door trim until final trim line. If Smith was installing the trim for the 64 run, I believe this practice ended for 65-67 and the Smith bodies then arrived less door trim.
                  The pic of this line looks nothing like the line at the Mill. There wasn't a wall on the right side, as I remember.
                  Quiz: There's one obvious way to tell the difference between a new St Louis body and a Smith body when viewed from the rear. Gold star for anyone that catches it. Bet you'll be the first Tony.
                  There's a mistake in the Burroughs book "Corvette Restoration, State Of The Art", and it's my fault. It has to do with this particular subject as the incorrect info came from me before the book was written.
                  • Robert Jorjorian
                    EXHAUST PANEL NOT INSTALLED 4 PAINT? *NM*
                    • Anthony F.
                      • December 1, 1985
                      • 191
                      • Michael H.
                        • January 29, 2008
                        • 7477
                        Re: The Wall....And Quiz....
                        Robert, Tony,
                        Yes, that's exactly right. For lack of a more convenient place to hang the rear lower panel during the paint operations, someone suggested it be loosly bolted in position on the body during the prime/paint processes, and that's exactly what was done. As Tony mentioned, only two bolts were used on two upper tabs but none used at the bottom position. This generally allowed the panel to fit the body poorly and it often showed as the ends of the panel were coated also.
                        The panel that was painted along with the body was typically NOT the same panel that eventually wound up on the completed vehicle. Once the body and panel were painted, the panel was removed and placed in a rack with other panels, in no particular order.
                        The rear tail light panel of a St Louis body would be absolutely bare of any coating under the area where the lower panel tabs covered it. There would be primer/body color in all of the unused bolt holes on the tail light panel.
                        St Louis bodies typically have no overspray on the rear bulkhead, ahead of the fuel tank. The lower panel prevented this overspray from going up inside the body. Smith bodies typically do have overspray in this area.
                        Tony, I remember the back wall with windows but I remember that area as the final trim line which would have been after the body was installed on the chassis. I don't remember a wall on or near the final line before body drop.
                        In the Burroughs book, I remember David asking me about the rear lower panel and the paint process. I explained that the panel was in place during prime/paint but later learned that this was only correct for St Louis bodies.
                        • Anthony F.
                          • December 1, 1985
                          • 191
                          • Michael H.
                            • January 29, 2008
                            • 7477
                            Pic Of The Mill Windows
                            Here's a shot of the air conditionong system at the Mill. Open windows and a breeze. This one should bring back a few memories Tony. It's the West entrance area. Behind the window is the area where engine compt blackout was done.
                            • Anthony F.
                              • December 1, 1985
                              • 191
                              Re: Pic Of The Mill Windows
                              Michael,
                              You know that they used to park test cars by the AIR CONDITIONER when I first started? The South Wall had the cafeteria and we walked by that black out area every day for lunch.
                              For the people who might be interested, the black out operator had "Shields" that he would lay on the fenders and place around the hood edges. No other masking was done so the over spray and lack of black out depended on the "Shields" and the operator.
                              I also remember coming in to work one day in 63 and there was a basket of steering wheels setting in that location along with a tree stump and a hatchet. Guess what they were doing?
