70 Z-28 - NCRS Discussion Boards
70 Z-28
  • Tim B.
    • November 1, 2004
    • 50
    70 Z-28
    Know it's not about Corvettes, but could use some expert advise. Is it possible due to the Norwood strike (or any other reason), that VIN numbers could have been built out of sequence?
    Bought a numbers matching 70 Z28. Cowl tag says June build. Engine, transmission, rear-end, support June, but according to a survey of VINs and build dates, this car should have been built in February.
    Is there an explanation, or do I need to contact my attorney?
    TIA
  • Michael S.
    • April 1, 1987
    • 364
    Re: 70 Z-28
    No, you do not need to contact your attorney since you did look at this car before your purchase and you DO bear some responsibility for your purchase either good or bad.
    1970 Camaro production at Norwood did not start until late January/early February in calender year 1970. 1969 model Camaro's were made at Norwood until December 1969. What "survey" of build dates and VINS did you look at for your information?
    • William C.
      • May 31, 1975
      • 6037
      Re: 70 Z-28
      Are you allowing for the late start of the '70 model year? the '69 model ran for more than 12 months due to the strike and late intro of the new body style. Without knowing the actual numbers you are dealing with that is one thing unique about the '70 Camaro builds.
      Bill Clupper #618
      • Tim B.
        • November 1, 2004
        • 50
        Re: 70 Z-28
        Have not seen car yet, Relied on seller pics. Friend won triple damages from same situation. It's called fraud.
        Registry is nothing offical. 70 Camaro owners listing Vin number, build dates options etc.
        www.camaro2ndgenerationregisrty.net
        • Michael S.
          • April 1, 1987
          • 364
          Re: 70 Z-28
          "Friend won triple damages from same situation. It's called fraud".
          Was your friend also to "busy/lazy" to look at the car in person and rely only on pictures?
          I'm picking on you because the information you desire is information YOU should have researched BEFORE you committed and/or spent YOUR money on an expensive collector car. Buyer's remorse in today's world must be spelled attorney!
          • Michael S.
            • April 1, 1987
            • 364
            Re: 70 Z-28
            Link to registry does not work. Goes to Marsfind.
            • Tim B.
              • November 1, 2004
              • 50
              Re: 70 Z-28
              Did not find the web-site until yesterday. Was looking for some constructive help. Hope you feel much better about yourself by putting me down. Glad the rest of the NCRS members I've met aren't as rude as yourself.
              • Steven C.
                • October 23, 2006
                • 186
                Re: 70 Z-28
                Tim:
                I've never, ever, heard of VIN numbers not following sequentially over time, and the "birthday" calculators based on end of month or end of week VIN records are usually pretty good for estimating when a particular car was produced, give or take a FEW days.
                An example of what you're hoping for is my '69 Corvette. The engine, transmission, and many other components were produced in March '69, and the car would have been produced in April, without the '69 strike. However, the VIN and trim tag date show that the car wasn't produced until the end of June '69.
                In my case, however, the VIN is later than "expected", and all documentation supports this (dealer check-off included). It sounds like you may have a "built" Z28, where everything matches but the VIN...perhaps a rustbucket Z28 cloned into a good earlier Camaro body.
                You may have legal recourse, I am not an attorney and don't have a clue if you do.
                Best of luck as you try to sort it out.
                Steve
                • Michael S.
                  • April 1, 1987
                  • 364
                  Re: 70 Z-28
                  I may be rude however I am 1 of only 2 who at least offered some help!
                  The following information is from www.nastyz28.com and my be of interest/help to you.
                  1970 Camaro Production: 12,578 6-cyl, 112,323 V8, 124,901 total.
                  Dealer Introduction: 2/26/70
                  Vehicle Identification Example: 123870N500001
                  First digit is GM Division: 1 = Chevrolet
                  Digits 2&3 are model series: 23 = 6-cyl, 24 = 8-cyl Camaro
                  Digits 4&5 are body type: 87 = 2dr. coupe
                  Sixth digit is model year: 0 = 1970
                  Seventh digit is N for Norwood assembly, L for Van Nuys.
                  Last six digits increased one with each car built at each plant, sequence started at 500001.
                  Dimensions Length: 188.0" Height: 50.1" Width: 74.4" Wheelbase: 108.0" Weight: 3313#
                  1970 Camaro Spotters Guide & New Features
                  1970 saw the introduction of the all new Second Generation Camaro. The 1st generation Camaro (1967 - 1969) was seen as a hasty response to the Ford Mustang. It was considered a compromise by some critics. There would be no compromises with this car. Due to production delays the 1970 Camaro was introduced in February 1970, half way into the production year. Because of this, some people will call the 1970 Camaro a 1970 1/2, but officially the car is a 1970 model year Camaro. Good things come to those who wait, and this car was met with rave reviews from nearly everyone. Chevrolet had a winner that would run for 12 years.
                  The 1970 Camaro was all new. It was longer (2.0"), lower (1.1") and wider (0.4") than the previous Camaro but still had a 108" wheelbase. It had a wider track (1.7" front, 0.5" rear). It's doors were longer (by 8") and the roof was moved back giving the car a sleek long hood, short rear deck which typifyed the pony-car. The convertible body style was no longer available. The windshield was swept back increasing visibility by 10% along with hiding the radio antenna within it (depending on radio choice). The rear view mirror was bonded to the windshield, no longer hung off the roof trim. The front subframe was redesigned to improve the structural integrity of the car. Efforts were made to eliminate road noise by strategically insulating various points on the car. The interior of the car was completely redesigned with a new dashboard, console & other interior trim.
                  The Camaro was also available with a distinctive appearance package called the Rally Sport (RPO Z22) option. Unlike the previous years hidden headlights, the RS package included a distinctive nose & bumper treatment, round front parking lights, hidden wipers and other trim. The Rally Sport package could be added to any model Camaro and when combined with the SS option became a RS/SS or when combined with the Z28 it became a RS/Z28.
                  Further details on the Rally Sport can be found here.
                  The "Super Sport" (RPO Z27) package was continued. This model offered stylish performance, and was the only way to obtain the 396 Big Block Chevy engine (actually displaced 402 cubic inches).
                  Complete information on the Super Sport can be found here.
                  The "Z28 Special Performance Package" (RPO Z28) was not only positioned as the top Camaro performer, but it put its money where its mouth was. Designed to race in the SCCA Trans Am Series, the 1970 rules changes allowing for the 5.7L engine meant the Camaro was able to now use the 350 engine. The previous Z28's were limited to 302 cubic inches and were known to be tempermental on the street. The bigger engine also allowed an automatic transmission to be used in the Z28 for the 1st time. Due to the solid lifter, high revving cam, Air Conditioning was still not available on the Z28. With a stout drivetrain, including a mandatory 12 bolt rear axle, and a tuned suspension, the Z28 was a match for anything found on the street, or at the track.
                  Complete information on the 1970 Z28 can be found here.
                  While 1970 is the 1st year of the Second Generation Camaro, it is also seen as the last of the high compression, solid-lifter cam, low geared ground pounding muscle cars. While the 1970 Camaro was being introduced, the muscle car market was disappearing, or at least changing. Among the other changes, highlights & distinguishing features for 1970 were....
                  Last year for 9+ compression engines
                  Only year 12 bolt rearend installed in performance 2nd gens
                  Variable ratio steering debut
                  Front disc brakes standard
                  COPO 9796 3 piece rear spoiler available
                  Only year a low-back style seat & headrest offered
                  Sunvisor was longer than other models
                  Only year a Chrome "C" used on header panel
                  Only year a "Camaro by Chevrolet" emblem used on trunk
                  Only year side marker lights didn't blink with signals
                  1970 Camaro Engine & Drivetrain Info
                  CID Config Bore & Stroke BHP @ RPM Torque @ rpm Comp Carb.
                  Base 250 L-6 3.875 x 3.53 155 @ 4200 235 @ 1600 8.5:1 1V
                  Base 307 V-8 3.875 x 3.25 200 @ 4600 300 @ 2400 9.0:1 2V
                  L-65 350 V-8 4.00 x 3.48 250 @ 4800 345 @ 2800 9.0:1 2V
                  L-48 350 V-8 4.00 x 3.48 300 @ 4800 380 @ 3200 10.25:1 4V
                  Z-28 350 V-8 4.00 x 3.48 360 @ 6000 380 @ 4000 11.011 4V
                  L-34 396 V-8 4.126 x 3.76 350 @ 5200 415 @ 3400 10.25:1 4V
                  L-78 396 V-8 4.126 x 3.76 375 @ 5600 415 @ 3600 11.0:1 4V
                  LS-6 454 V-8 4.251 x 4.00 450 @ 4600 500 @ 3600 11.25:1 4V
                  Note: Actual displacement of L-34 and L-78 "396" V-8's is 402 cid. LS6 engine never made it to production.
                  Engine Suffix Codes
                  CCG: 250ci, mt CKN: 396ci, at, hp CNK: 350ci, pg, 300hp/SS
                  CCH: 250ci, ex, pg CKO: 396ci, mt, sp CNM: 350ci, pg, tb
                  CCI: 250ci, mt CKR: 396ci, mt CNN: 350ci, at, tb
                  CCJ: 250ci, ex CTC: 350ci, at, z CRE: 350ci, at, 300hp/SS
                  CCK: 250ci, at, tp CNC: 307ci, mt CCL: 250ci, mt, tp
                  CCM: 250ci, pg, tp CNE: 307ci, pg CND: 307ci, mt
                  CCZ: 250ci, at, mt CNF: 307ci, at CJF: 396ci, mt, 350hp/SS
                  CJH: 396ci, mt,375hp/SS CNH: 307ci, ex, pg CNG: 307ci, ex, mt
                  CJI: 396ci, at,350hp/SS CNI: 350ci, mt, tb CRF: 250ci, mt
                  CJL: 396ci, at CNJ: 350ci, mt, 300hp/SS CRG: 250ci, ex, mt
                  CTA: 307ci, at, ex CTB: 350ci, mt, z CJK: 396ci, at,375hp/SS
                  CTW: 396ci, at, hp CTX: 396ci, hp, mt CTY: 396ci, at, sp
                  Abbreviations: at = Turbo Hydra-Matic automatic, ci = cubic inch, ex = export, hp = high performance, pg = Powerglide automatic transmission, mt = manual transmission, sp = special high performance, tb = two barrel carburetor, tp = taxi/police, Z = RPO Z28 special performance package, SS = used in SS option.
                  Engine Code Example: V0328CJH - (396 375hp Assembled in Flint assembly plant on March 28)
                  Click here for further engine decoding information
                  1970 Camaro Powerteams
                  Base Base L-65 L48 Z-28 L-34 L-78 LS-6
                  250 307 350 350 350 396 396 454
                  3- and 4-spd. 1 2.85:1 2.85:1 2.54:1 2.52:1 2.52:1a 2.20:1a 2.52:1a 2.20:1a
                  manual trans 2 1.68:1 1.68:1 1.80:1 1.88:1 1.88:1 1.64:1 1.88:1 1.64:1
                  ratios 3 1.00:1 1.00:1 1.44:1 1.46:1 1.46:1 1,27:1 1.46:1 1.27:1
                  4 -- -- 1.00:1 1,00:1 1.00:1 1.00:1 1.00:1 1.00:1
                  R 2.95:1 2.95:1 2.54:1 2.59:1 2.59:1 2.26:1 2.59:1 2.26:1
                  Clutch diam., in. 9.12 10.34 10.34 11.0 11.0 11.0 11.0 11.0
                  Axle ratios S 3.08:1 3.08:1 3.36:1 3.31:1 3.73:1 3.31:1 3.55:1 3.31:1
                  E
                  P -- 3.08:1 3.36:1 3.31:1 4.10:1 3.31:1 4.10:1 --
                  Powerglide & 1 1.82:1 1.82:1b 2.52:1 2.52:1 2.48:1 2.48:1 N.o. 2.48:1
                  Turbo Hydra- 2 1.00:1 1.00:1 1.52:1 1.52:1 1.48:1 1.48:1 N.o. 1.48:1
                  matic ratios 3 -- 1.00:1 1.00:1 1.00:1 1.00:1 N.o. 1.00:1
                  R 1.82:1 1.82:1 1.93:1 1.93:1 2.08:1 2.08:1 N.o. 2.08:1
                  Axle ratios S 2.73:1 2.73:1 2.73:1 3.07:1 3.73:1 3.31:1 N.o. 3.31:1
                  E - -- -- - -- - N.o. --
                  p - -- 3.31:1 3.07:1 4.10:1 3.31:1 N.o.
                  Only manual transmission available with base 250 and 307 was the 3-speed.
                  Only manual transmission for larger V8's were 4-speeds.
                  a = Alternate 4-speed transmissions offered at no extra cost.
                  b = Turbo Hydra-Matic with 2.52:1 low range was also available for the 307 V-8.
                  S = Standard ratio, E = Economy, P = Performance
                  Transmission Codes
                  Type Plant Code
                  3-Speed Muncie S
                  3-speed McKinnon K
                  4-Speed (L.D. cast iron case) Muncie R
                  4-Speed (H.D. aluminum case) Muncie P
                  Powerglide Cleveland C
                  Powerglide McKinnon E
                  Turbo Hydramatic 350 Cleveland B
                  Turbo Hydramatic 350 Toledo Y
                  Transmission Code Example: P0C27A - (1970 Muncie 4 speed, assembled March 27, (M20 w/2.52 1st gear)
                  Type Code:
                  R3 = 3 speed manual (L6 & V8).
                  WB = 4 speed manual (V8)
                  UD = Powerglide (L6), UF = Powerglide (V8)
                  GW = TH350 (V8)
                  TH400 transmission code is CK or CY (for BBC) and is stamped on a tag which is rivited to transmission case.
                  Click here for further transmission decoding information
                  Rear Axle Codes
                  COA 2.56:1 COM 2.56:1 COZ 3.73:1 Locking
                  COB 2.56:1 CON 2.56:1 Locking CRA 3.07:1
                  COC 2.73:1 COO 4.10:1 CRB 3.31:1
                  COD 2.73:1 Locking COP 2.73:1 Locking CRC 3.55:1
                  COE 3.08:1 COR 3.73:1 Locking CRD 3.73:1
                  COF 3.08:1 Locking COS 3.07:1 CRE 4.10:1
                  COG 3.36:1 COT 3.07:1 Locking CRF 2.56:1
                  COH 3.36:1 Locking COU 3.31:1 CRG 2.56:1 Locking
                  COI 3.08:1 COV 3.31:1 Locking CRH 3.08:1
                  COJ 3.08:1 Locking COW 3.55:1 CRI 3.08:1 Locking
                  COK 3.36:1 COX 3.55:1 Locking CRX 2.73:1
                  COL 3.36:1 Locking COY 3.73:1 CRY 2.73:1 Locking
                  Rearend Code Example: COZ0327GE - (Chevy sourced 3.73 Posi, Assembled on March 27 w/ Eaton Posi)
                  Click here for further axle decoding information
                  Click Here for general axle info and tooth combinations
                  1970 Camaro Factory Options
                  RPO Description Qty Retail *
                  12387 Camaro Sport Coupe, 6-cylinder 12,578 $2,749.00
                  12487 Camaro Sport Coupe, 8-cylinder 112,323 2,839.00
                  AK1 Belts, custom deluxe 13,218 12.15
                  AS4 Belts, custom deluxe rear shoulder 89 26.35
                  A01 Soft Ray Tinted Glass, all windows 71,363 37.95
                  A31 Power Windows
                  B37 Floor Mats, color-keyed front and rear 23,708 11.60
                  B93 Guards, door edge 35,577 5.30
                  C08 Vinyl Roof Cover 43,221 89.55
                  C24 Windshield Wipers, hide-a-way 40,143 19.00
                  C50 Defroster, rear window 8,814 26.35
                  C60 Air Conditioning 38,565 380.25
                  D34 Mirror, visor vanity 7,423 3.20
                  D35 Mirrors, sport right and left remote exterior 31,726 26.35
                  D55 Console - 59.00
                  D80 Spoiler, rear deck - 32.65
                  F41 Suspension, special purpose front and rear - 30.55
                  G80 Positraction, rear axle 19,752 44.25
                  J50 Power Brakes, front disc, rear drum 59,607 47.40
                  J52 Front disc brakes
                  L22 6 Cylinder Engine, 250 CID
                  L34 Engine, 396ci, 350hp Turbo-jet V8 (SS) 1,864 152.75
                  L65 Engine, 350ci, 250hp Turbo-Fire V8 34,780 31.60
                  L78 Engine, 396ci, 375hp Turbo-jet V8 (SS) 600 385.50
                  M20 Transmission, 4-speed wide range 12,191 205.95
                  M21 Transmission, 4-speed close ratio 5,302 205.95
                  M22 Transmission, 4-speed heavy-duty close ratio 1,185 232.35
                  M35 Transmission, Powerglide automatic 19,520 174.25
                  M38 3-speed automatic transmission, 300 deluxe
                  M40 Transmission, Turbo Hydra-Matic automatic 71,832 200.65
                  NA9 Emission Control, required for California 15,862 36.90
                  N10 Dual Exhaust
                  N33 Tilt Steering Column 6,735 45.30
                  N40 Power Steering 92,640 105.35
                  PL3 Tires, E78x14 belted white stripe 56,186 26.05
                  PL4 Tires, F70x14 belted white letter 20,783 65.35
                  PX6 Tires, F78x14 belted white stripe 12,893 43.30
                  PY4 Tires, F70x14 belted white stripe 15,776 65.70
                  P01 Wheel Covers, bright metal 73,292 26.35
                  P02 Wheel Covers, special 3,532 79.00
                  P06 Deluxe wheel trim cover
                  T60 Battery, heavy duty 5,518 15.80
                  U14 Special Instrumentation 17,842 84.30
                  U35 Clock 15,533 15.80
                  U63 Radio, AM pushbutton 110,779 61.10
                  U69 Radio, AM-FM pushbutton 8,586 133.80
                  U76 Windshield antenna
                  U80 Speaker, rear seat 20,583 14.75
                  VF3 Bumpers, deluxe front and rear 1,605 36.90
                  V01 Radiator, heavy duty 1,509 14.75
                  Y02 Custom Front Seat
                  Y03 Custom Rear Seat
                  Y10 Custom Trim
                  YD1 Axle, trailering ratio 132 12.65
                  ZJ7 Wheels, rally 15,197 42.15
                  ZJ9 Auxiliary Lighting Group 8,307 13.70
                  ZP5 Appearance Guard Group (Includes B93, B37, D34)
                  ZQ2 Operating Convenience Group (Includes U35, D35, C50)
                  ZQ9 Axle, performance ratio 3,161 12.65
                  Z21 Style Trim Group 43,344 52.70
                  Z22 Rally Sport Package 27,136 168.55
                  Z23 Interior Accent Group 36,550 21.10
                  Z27 Super Sport Package 12,476 289.65
                  Z28 Special Performance Package 8,733 572.95
                  Z87 Custom Interior 21,059 115.90
                  * Option prices are retail for base model. Prices could be reduced or option could be had at no charge if it was included as standard equipment on the Z28, Rally Sport or Super Sport or as part of an option package.
                  1970 Camaro Exterior & Interior Color Codes
                  Trim Tag (Norwood Built Camaro)
                  Trim Tag (LA Built Camaro)
                  The trim tag, located on the cowl area identifies significant information about your car. Move mouse over code on above trim tag examples for detailed description or Click Here for general trim tag decoding information.
                  Paint Code Color Vinyl Top Stripes Interiors Available
                  10 Classic White Bk-Dg-W Bk B-Bk-Bkb-Bkg-Bkw-Dg-S-Sw
                  14 Cortez Silver Bk-W Bk B-Bk-Bkb-Bkg-Bkw-Dg-S-Sw
                  17 Shadow Gray Bk-W Bk-W Bk-Bkg-Bkw-Dg-S-Sw
                  25 Astro Blue Bk-W Bk-W Bk-Bkw-Sw
                  26 Med Blue Bk-W Bk-W B-Bk-Bkb-Bkw-S-Sw
                  43 Citrus Green Bk-W Bk-W Bk-Bkg-Bkw-Dg-Sw
                  45 Green Mist Bk-Dg-W Bk-W Bk-Bkg-Bkw-Dg-S-Sw
                  48 Forest Green Bk-Dg-W W Bk-Bkg-Bkw-Dg-S-Sw
                  51 Daytona Yellow Bk-W Bk Bk-Bkg-Bkw-Dg
                  53 Camaro Gold Bk-W Bk-W Bk-Bkw-Sw
                  58 Autumn Gold Bk-W W Bk-Bkg-Bkw-Dg-S-Sw
                  63 Desert Sand Bk-W Bk-W Bk-Bkg-Bkw-Dg-S-Sw
                  65 Hugger Orange Bk-W W-Bk Bk-Bkw-Sw
                  67 Classic Copper Bk-W W Bk-Bkw-S-Sw
                  75 Cranberry Red Bk-W Bk-W Bk-Bkw-S-Sw
                  Paint type: "Magic-Mirror" Acrylic Lacquer. Two-tone combinations not offered. vinyl Top offered at additional cost.
                  1970 Vinyl Top Code - Upper Body Color Code
                  A = White, B = Black, C = Dark Blue, G = Dark Green, H = Dark Gold
                  Interior Codes:
                  710
                  Sw/std
                  711
                  Bk/std
                  712
                  Bk/cv
                  713
                  Bkw/cc
                  714
                  Bkb/cc
                  715
                  B/std
                  716
                  B/cv
                  720
                  Bkg/cc
                  723
                  Dg/std
                  724
                  Dg/cv
                  725
                  Bk/cc
                  726
                  S/std
                  727
                  S/cv
                  730
                  Sw/cv
                  Abbreviations: B = Blue, Bk = Black, Bkb = Black with blue accents, Bkg = Black with green accents, Bkw = Black with white accents, cc = Custom cloth, cv = Custom vinyl, Dg = Dark green, S = Saddle, Sw = Sandlewood, std = standard, W = White.
                  1970 Camaro RPO Breakouts & Model Specifics
                  1970 Z21 Style Trim - Includes body colored insert on door handles, bright window, body, sill and hood panel moldings plus bright accented parking lights, taillights and backup lights. (Included with Rally Sport option).
                  1970 Z22 Rally Sport - Includes special black painted grille with special rubber tipped vertical center bar and resilient body color grille frame; Independent LH and RH front bumpers replacing full width bumper; license plate bracket mounted below RH bumper; parking lights with bright accents mounted on grille panel; Hide-a-Way windshield wipers with black-chrome finished arms and articulated left hand blade; bright window, hood panel and body sill moldings; body colored insert on door handles; RS emblem on steering wheel; Rally Sport front fender nameplates; bright accented taillights and back-up lights. (RS emblems deleted with SS or Z28 option).
                  Click here for information on How to verify a Rally Sport
                  Click here to view a 1970 RS [ Side view | High Angle Front View | Front 1/4 Side view ]
                  1970 Z23 Accent Group Interior - Includes additional instrument cluster lighting, wood grained accents on instrument cluster and steering wheel (included in Custom Interior option).
                  1970 Z27 Super Sport - Includes 300-hp Turbo-Fire 350 engine and bright accents & dual exhaust; power brakes, special ornamentation; special hood insulation; F70-14 bias belted ply white lettered tires, 14" x 7" wheels; black painted grille; hide-a-way windshield wipers with black chrome finished arms and articulated left hand blade; SS emblems on steering wheel, fenders and grille (exc. when combined with RS), available with V8 only, available with 4-speed manual or automatic transmission only, optional engines are L34 350 hp 396 and L78 375 hp 396). 396 recieved black painted rear panel and forced RPO F41 onto the car. L78 required positraction.
                  Total SS Production = 12,476 L48/350 ci = 10012 L34/396 ci = 1864 L78/396 ci = 600
                  Carburetor Part numbers Distributor Part Numbers
                  350 ci - 7040203 350 ci - 1111997
                  350 ci w/at - 7040202 396 ci - 1112000
                  396 ci - 7040205 396 ci - 1112000
                  396 ci w/at - 7040204
                  396 ci 375hp w/EEC - 3957477 (Holly R-4557A)
                  396 ci 375hp w/EEC - 3967479 (Holly R-4491A)
                  396 ci 375hp w/EEC & at - 3969898 (Holly R-4492A)
                  396 ci 375hp w/EEC & at - 3969894 (Holly R-4556A)
                  BBC Intake Manifold: 3963569
                  1970 Z28 Special Performance Package
                  Mark D's 1970 Z28. Click image to view more info
                  Other Views: Z28 Sales literature
                  Engine: Includes special 350 CID, 360-bhp V-8 derived from Corvette LT-1. Four-bolt mains, forged steel crank, TRW impact extruded pistons, 11:1 c.r. Standard cam was 1969 optional cam, with 317-degree intake duration and 346-degree exhaust. Lift: 0.458 inches intake and exhaust, Carburetion by Holley 780-cfm (4150) 4-barrel atop new high-rise aluminum manifold. Spark via aluminum single-point, vacuum controlled distributor. High-performance oil pump, baffled pan, windage tray. Cast aluminum rocker covers with internal galleries. Twin-pulley fan drive. Mechanical valve lifters. Same heads and valve sizes as 302. Chrome dressup kit, larger-capacity radiator.
                  Click here to see the specific LT-1 Engine Components.
                  1970 Z28 Carburetor (780 cfm Holley) A/T List 4490 GM # 3972120
                  4 Spd List 4555 GM # 3972121
                  A/T w/NB2 List 4554 GM # 3972122
                  4 Spd w/NB2 List 4489 GM # 3972123
                  Transmission: Mandatory choice of same Muncie 4-speeds as before, with special 2400-rpm-stall torque converter Turbo Hydra-Matic optional. First year an automatic transmission could be ordered in the Z-28.
                  Clutch: New 11-inch unit.
                  Rear Axle: GM 12 bolt, unchanged from 1969. Positraction optional. 3.73:1 ratio standard.
                  Brakes: 11-inch, vented, cast-iron front discs with vacuum assist standard. Rear 9.5-inch drums.
                  Front Suspension: Similar to previous Camaro's. Z-28 anti-roll bar 1.0-inch diameter instead of standard 0.6875-inch unit.
                  Rear Suspension: RPO F-41 special suspension standard, including 5-leaf rear springs, 125 lb./in. spring rate, staggered heavy-duty shocks, link-type rear stabilizer bar.
                  Steering: Standard non-power steering ratio 18.8:1 or 4.1 turns lock to lock. Optional power steering came as variable-ratio at 14.3-10.9:1 for 2.3 turns lock to lock.
                  Wheels & Tires: 15 x 7 steel wheels painted dull grey with bright lugnuts, center caps with blue bow-tie and trim rings,
                  Wheel Code: AU, Part #: 3983045, Center cap part #: 3989479, Trim Ring part #: 3984524.
                  F60-15 fiberglass-belted white letter tires standard.
                  Click here to see the specific 1970 Z28 Chassis Specifications.
                  Other Options, equipment, facts: One-piece low-profile rear spoiler standard; 3-piece high spoiler (COPO 9796) available optionally after Apr. 20, 1970; special instrumentation; dual exhaust; black painted grille; Z28 emblems on grille, front fenders and rear deck lid; rear bumper guards; special hood insulation; special paint stripes on hood and rear deck.
                  Total Production: 8733
                  1970 Z87 Custom Interior - Includes deluxe seat (in cloth or vinyl) and sidewall trim; glove compartment light and additional instrument cluster lighting; wood grained accents on instrument cluster, steering wheel and door trim panels; luggage compartment mat plus special engine compartment, hood and interior insulation.
                  • Tim B.
                    • November 1, 2004
                    • 50
                    Re: 70 Z-28
                    Thanks for your reply. To do what your saying, the block and transmission would have to be restamped, correct? Doesn't appear to have been. No grinding/flat areas.
                    • Mark #28455
                      not restamped
                      They may have started with an original June Z28 trim tag and drivetrain from a rusty car or junkyard (or perhaps a stolen car) and pieced it together with a donor body or VIN tag from the early car.
                      To help rule out a stolen car, take the VIN number from the engine and trans and call your local police and have them run it. If you're lucky, it will come up clean. Then you likely have a car pieced together from 2 others. What's better? To leave it as is, or to go to your state and try to get a "state issued" VIN tag replacement. The replacement VIN tag would be OBVIOUSLY not original, but at least you wouldn't have to keep explaining why the VIN and drivetrain don't match up!
                      Mark
                      • Tim B.
                        • November 1, 2004
                        • 50
                        Re: not restamped
                        But the engine and transmission have the February VIN that matches the VIN on the windshield. If it was a June drivetrain it would have a different non-matching VIN, Right?
                        • Steven C.
                          • October 23, 2006
                          • 186
                          Re: 70 Z-28
                          I'm not suggesting any restamping occurred, rather I am trying to explain how a car could have been created (in the marketplace, not by GM), with an engine/drivetrain from June 1970 and a VIN from February 1970.
                          My understanding is that you did some research and some due diligence before you purchased the car, and that you are trying to explain the date discrepancy between the drivetrain (which seems like correct, matching dates and codes) and the body (which seems like a correct 1970 Camaro VIN).
                          Please let me know if I have misunderstood.
                          Steve
                          • Steven C.
                            • October 23, 2006
                            • 186
                            Re: not restamped
                            Tim,
                            I'm trying to help to the best of my limited ability, but you are putting out conflicting info:
                            The engine (and transmission) can't easily support both June and February build dates.
                            I think that maybe you have a "bad" trim tag, or perhaps you are deciphering the date code from the trim tag incorrectly, due to the weird production year? Should be a letter and 2 numbers.
                            Maybe everything is cool!
                            Steve
                            • William C.
                              • May 31, 1975
                              • 6037
                              Re: 70 Z-28
                              I've been trying to follow this thread but I have to admit to being a little confused. It would be much more helpful if you supplied the numbers we are comparing, what is the vin on the windshield? What is the engine stamp number set including the engine VIN? What is the body build date code on the trim tag? Is it a Norwood or Van Nuys car on the trim tag? Correct rivets in all locations?
                              Bill Clupper #618
