Headlight Switch Removal - '61 - NCRS Discussion Boards
  • Mike B.
    • November 1, 2004
    • 389
    How does one remove the headlight switch knob ('61) so as to remove the switch from the dash? It appears that the knob and shaft are one unit, but I hesitate to tug or turn it too aggressively.
    Thanks in advance,
    Mike
  • Bob R.
    • June 30, 2002
    • 1595
    Re: Headlight Switch Removal - '61
    I believe that all the old chevy headlight switches are the same. If that is the case then there is a spring loaded button on the body of the switch. Push in on it and the knob will pull completely out.
    • Mike E.
      • February 28, 1975
      • 5138
      First pull the shaft out as if you are turning the lights on--then depress the button Bob mentioned, and as you're pushing the button, pull the shaft out the rest of the way and it will come out of the switch.
      • Mike B.
        • November 1, 2004
        • 389
        I know of that spring loaded button but now I know what it is used for!
        Thanks to both of you for the info. One learns something every day.
        Mike
