C2 Deck Lid Vinyl Trim - NCRS Discussion Boards
  • James S.
    • July 31, 1990
    • 126
    I have seen two different versions of the rear deck vinyl trim strip. One uses a larger acorn nut, approximately 7/16, to secure the strip and the other uses a smaller 5/16 acorn nut.
    Which is original to a 1967? Are there different versions for C2's? Does any vendor supply the original style?
  • Mike E.
    • February 28, 1975
    • 5138
    Re: C2 Deck Lid Vinyl Trim
    Jim--
    My May car (untouched) has 7/16 acorn nuts.
    • Michael H.
      • January 29, 2008
      • 7477
      5/16" On My 66 *NM*
      • Dino L.
        • February 1, 1996
        • 694
        Re: 5/16" On My 66
        The biggest difference I see on aftermarket ones are the seams go completely bead to bead where the originals stop and are flat before the bead...stand out easily.
        Dino Lanno
        • James W.
          • December 1, 1990
          • 2657
          Jim,
          The smaller 5/16" acorn nut is correct. I spent Saturday afternoon at the Corvettes at Carlisle meet buying all the good usable original vinyl deck lid strips and acorn nuts I could find. I have found that if you are missing one or all of the acorn nuts and washers from and original deck lid strip you can't find a correct acorn nut to fit an original deck lid strip. All of them from the aftemarket vendors sell the 7/16" version. Al Knock deck lid strips have the 7/16" size of the acorn nut.
          James West
          Omaha, NE.
          • James S.
            • July 31, 1990
            • 126
            What I am concluding from the responses is that the rear deck vinyl strip that uses the 5/16th inch acorn nut is correct for 67's.
            LIC has the 5/16th acorn nuts in their Catelog #24, section 19, part number 43B. LIC also has listed a lid trim vinyl with hdwe. I will check tomorrow to determine if the replacement vinyl strip available from LIC uses the 5/16th inch acorn nuts.
