66 Warning lights - NCRS Discussion Boards
66 Warning lights
  • Rob M.
    • April 30, 2003
    • 657
    66 Warning lights
    I lost plenty of points during my opps check on my 66 SB because the headlamp warning light doesn't light up. I know this can be fixed with a new bulb (if I can get my hand up behind the cluster). But, I also lost points because the parking brake light didn't flash. It lights up, but doesn't flash. How do I go about solving that problem?
    Thanks in advance,
    Rob
    Rob
    '66 327/300 Regional Top Flt
    '08 6 speed coupe
  • Joe C.
    • August 31, 1999
    • 4598
    Re: 66 Warning lights
    Rob,
    They are both special blinking bulbs. They make-break is a similar way as the flasher can.
    http://www.licorvette.com/pdfcatalogfiles/cat/39.pdf
    See item 48A.
    Joe
    • Rob M.
      • April 30, 2003
      • 657
      Joe,
      Thanks, and I hope it's that simple.
      Rob
      Rob
      '08 6 speed coupe
      • William C.
        • May 31, 1975
        • 6037
        GE # 257 Bulb is what you need.
        Bill Clupper #618
