1966-427 oil pan baffle fastener torque - NCRS Discussion Boards
  • Richard E.
    • 247
    Is there a torque specification for the nuts which fasten the oil pan baffle to the main bearing studs? Should lock nuts with flat washers be used? Any special type lock nut required? Thanks.
    • 43240
    Re: 1966-427 oil pan baffle fastener torque
    Rich-----
    GM never published a toque spec for these nuts. However, I use a "standard" value for 3/8-16 grade 8 nuts of 30-35 lb/ft.
    You can use self-locking nuts with a flat washer. However, I use regular nuts with Lock-Tite threadlocking compound and a flatwasher.
