'76 Gas Tank Metal Shroud - NCRS Discussion Boards
  • Scott Marzahl
    Does anyone know when GM started installing a metal covering over the top of gas tank and what purpose it is supposed to serve. The one on this '76 we are doing a body off on is rusted to bits. I'm thinking we will just not replace it unless it has some special purpose I'm not aware of.
  • Paul B.
    • April 30, 1995
    • 482
    Re: '76 Gas Tank Metal Shroud
    Scott, being an owner of both a '74 "leaded gas" Corvette and a '75 "no lead" gas Corvette, this shield was used on '75-'77 Corvettes only, along with the rubber bladder tank which was used these three same years. I would guess that it's just an added rear collision safety shield. The Ford Pinto fiasco probably helped create it. When I re-did the tank assembly and fuel hoses I also left it off.
