Factory body mount shim procedure? - NCRS Discussion Boards
  • Bob B.
    • March 1, 2003
    • 831
    Hi all,
    I used Noland Adams' figure to dutifully record all my shim info for restoring my 1960. However, I am curious about a couple of things:
    (1) What procedure did the factory use to determine the amount of shimming needed?
    (2) What determined the use of the metal shims versus the cardboard?
    Bob
  • Roy B.
    • February 1, 1975
    • 7044
    Re: Factory body mount shim procedure?
    "What determined the use of the metal shims versus the cardboard?"- Rubber was just to cushion it the metal shims used to close the rear door gap. No real need to worry about the original shims , when you replace the body back on the doors is what determines shim amount and location
      Bob -
      C1 frames were measured and marked for shims in a fixture at the beginning of the moving frame upside-down line; this process moved to the stationary frame upside-down "buck" ahead of the moving conveyor for the C2.
      • Verne Frantz
        John,
        Do you know if that procedure was applied to Passenger cars as well?
        thanks
        Verne
          Verne -
          I don't recall, but I would think so; I was never heavily involved with full-frame passenger cars - just unitized bodies, Corvettes, and half-frame Camaros.
          • Verne Frantz
            Thanks John,
            Just for the record, I've never encountered any "shim directive" markings on any of the full size frames I've seen. That's why I asked. I know shims were used though. Maybe they just figured it out as they put it together.....?
            thanks
            Verne
