the candle power will be tested at the FL meet - NCRS Discussion Boards
  • Geoff C.
    • May 31, 1979
    • 1613
    OMG how is this to be accomplished?
    A Dim Bulb
    • 15601
    • Rich G.
      • August 31, 2002
      • 1397
      Re: the candle power will be tested at the FL meet
      Once they separate the dim bulbs from the bright bulbs, will they be allowed to return to their cars?
      • Kevin M.
        • November 1, 2000
        • 1271
        • Dick W.
          • 10483
          A Dim Bulb Oh, I thought you were talking about the one behind the keyboard, not headlamps...
          Dick Whittington
          • Clem Z.
            • January 1, 2006
            • 9427
            what is next,chassis dyno to check to make
            sure the engines have not been modified to make more HP than "as delivered"
              • September 30, 1999
              • 710
              Check The Doors
              Make sure there is NO play anywhere as they should be just like NEW.
              • Chuck G.
                • May 31, 1982
                • 2034
                Will they be testing for original air in the tires? Chuck
                • John D.
                  • December 1, 1979
                  • 5507
                  Dr. Chuck, Don't forget the green washer fluid in your 63. John
                  • Chuck G.
                    • May 31, 1982
                    • 2034
                    Hmmm. Have the blue stuff. Can I add some of my wife's yellow food coloring to turn it green? Chuck
                      • May 31, 1974
                      • 8389
                      urine works better that FD&C 12 Yellow food coloring.. mike
                      • Kent K.
                        • December 1, 1982
                        • 1139
                        Hey Mikie, that depends on how many brewskies you had.
                        Regards, Kent #6201
                        Kent
                        NCM Founder - Member #718
                        • John D.
                          • December 1, 1979
                          • 5507
                          Dr. Chuck, I see you missed one of the better posts on the dumb board. Walmart sells the green washer fluid and so does just about every auto store around here. In fact the green has suddenly taken over and the blue is in short supply. Go figure. John
                          • Geoff C.
                            • May 31, 1979
                            • 1613
                            • Dick W.
                              • 10483
                              Re: Kent Moore Glossometer
                              How do you measure the "dim bulbs" behind the keyboard?
                              Dick Whittington
