C2 Pwr Steering Conversion Ques. - NCRS Discussion Boards
  • Donald M.
    • December 1, 1984
    • 498
    I'm planning on adding power steering to my '67 327/300, non a/c car. I was wondering if you could use the existing lower crank pulley mounting bolts to attach the "add-on" P/S belt pulley to the front of the crank pulley? I have scoured the catalogs and can find no special longer bolts for this attachment.Also, any problems or pitfalls connected with this conversion?
    Thanx,
    Don
  • Scott Marzahl
    Re: C2 Pwr Steering Conversion Ques.
    Pitfalls, maybe, the biggest problem was getting all the correct pulleys, the AIM was totally messed up, at least for the L-79 option.
    Search the archives and you should find plenty of info on the correct pulley P/Ns or give LICS a call and they should have the entire set you need.
