What is the correct speedo tooth gear for... - NCRS Discussion Boards
  • yello58
    3.36 gears and 3.55 gears in a 1958 Corvettes; Automatic. Thanks!
    • 43235
    Re: What is the correct speedo tooth gear for...
    "yello58"------
    With 3.55 rear gear and powerglide, the correct gear is a 21 tooth gear of GM #3708142. For 3.36 ratio and powerglide the correct gear is a 20 tooth gear of GM #3708246. Unfortunately, both are long-since GM-discontinued. A speedometer shop might be able to fix you up with a replacement, though.
