67 HP 327 Spark Plug - NCRS Discussion Boards
  • Salvatore I.
    • April 1, 2004
    • 114
    I am going to tune my 67 327/350. But before I do, wanted to get some advice on the best plugs to use. I have AC Delcos in the motor now (R type as there is a radio and all of the correct engine shielding is in place). I have been looking at champion as a replacement, denso or split fire plugs...
    I drive the car as much as I can, which mostly limits it to every weekend and do a combination of highway and street driving. I tend to not just start the car and move it from one end of the driveway to another, if you follow me. The car is not a trailer queen. I need a mid-range plug, given how I use the car...
    Can I get some advice on the best choices to go with and the numbers of the plugs? Thanks for the suggestions....
  • Tom Merkel
    Re: 67 HP 327 Spark Plug
    Sal - I use OEM AC R43's or 45's in the same L-79 that you have. It's a driver, and not a trailer queen, either. Runs like new. Power, start-ups, cruise. Perfect.
    Stay away from extended tips; they didn't work for me.
    Tom
    • Wayne K.
      • December 1, 1999
      • 1030
      Sal,
      For all around driving I've had good luck with a 45 heat range plug. I prefer extended tip plugs ever since I kept having fowling problems with regular plugs in a LT-1 I previously owned. I've never had a fowled plug with an extended tip. Just my personal choice.
      Wayne
        • 15694
        The OE plug was non-resistor AC heat range "4", which is AC 44, but AC no longer offers non-resistor plugs. AC heat range "5" is a better heat range for normal driving - more fowling resistant than heat range "4", so the best AC choice is R45.
        NGK and Denso both offer non-resistor plugs equivalent to the AC 45, the B4 and W14-U respectively, so for a driver I recommend either of these plugs. This advice applies to ALL small blocks, regardless of horsepower rating.
        • John D.
          • December 1, 1979
          • 5507
          Sal, The unltimate AC spark plug for your car is the AC46. Tough to find and rather pricey. One set should last you forever. If you foul out a 46 you have problems. Don't forget that we preach spark plus too much. Alsoimportant is to have the proper ignition coil to fire those plugs. John
          • Salvatore I.
            • April 1, 2004
            • 114
            Thanks everyone for the great feedback...
            Duke,
            Pardon my question, the NGK and Denso plugs are non-resisitors...can I use them without issue on a car with a radio?
            Thanks......
              • 15694
              Yes, as I said the OE plugs were non-resistor. GM did not start using resistor plugs until circa 1969.
              • Salvatore I.
                • April 1, 2004
                • 114
                Thanks for the great information...sorry, I missed the point you made on the OE plugs from GM, but I got it now...Thanks for the useful advice...
                Sal
                • Jim T.
                  • March 1, 1993
                  • 5351
                  Sal I have always used Champion plugs in my 64 327/300, 68 327/350 and my 70 350/300. I used them for their extended tip feature. I have read of some that like the Autolite plugs. I installed Bosh plugs in my 85 several thousand miles ago and still getting good service. There is a lot to chose from.
