1972 454 carb isolator - NCRS Discussion Boards
  • John S.
    • June 30, 2004
    • 4
    I am doing some carb work on my '72 454 4 spd. coupe. I have a stock cast iron
    intake manifold and am mounting a new 650 spreadbore Holley with mechanical secondaries and divorced choke. My question concerns the base gasket/isolator
    that I need. Is the isolator .25 thick? Does it have 4 separate holes for
    the primaries and secondaries or is it all open inside? Or do I require a
    different gasket setup altogether? I previously had a .25 inch isolator (with
    hard plastic grommets at the corners) and a model 4165 Holley setup. The
    isolator came with a Holley renew kit and was all open inside. It worked OK
    but I'm just making sure I'm doing the right thing. Thanks for your response!
    • 43221
    Re: 1972 454 carb isolator
    John------
    The original insulator gasket for 1972 was a "full open" plenum design gasket. It did not have 4 holes.
