Timing??? - NCRS Discussion Boards
Timing???
  • Roy B.
    • February 1, 1975
    • 7044
    Timing???
    I thought I might mention how I time my engines in my 55 and 67 with all the talk about timing and vacuum advance , First I don't trust the harmonica balance ( the outer ring could move)or the vacuum advance . So after the engine is warmed up and knowing it fires on all 8 OK, Carb working good. I loosen the Dist. Hold down then turn the Dist, one way or another while snapping the Carb rod full open, I do that while each time moving the Dist. Till I get NO hesitation snapping the Carb full open . Then I lock down the Dist clamp and call it DONE.
    Now am I wrong ? Been timing my Corvettes that way for 40 years , could not afford a timing light when I was young and my Corvettes and cars run great with no pinging!!
  • Kurt B.
    • July 31, 1996
    • 971
    Re: Timing???
    Roy,
    That is awesome. I learned something today. Thanks for the tip.
    Kurt
    • Roy B.
      • February 1, 1975
      • 7044
      Re: Timing???
      Wait! Kurt ! others may say I'm nuts!!!
      • Kurt B.
        • July 31, 1996
        • 971
        Re: Timing???
        Let them say what they want: the bottom line is if it works, it works !
        Can't argue with that, especially since it hasn't failed you in 40 years.
        It also compensates for slipped harmonic balancers and vacuum advances.
        When you use this method, do you leave the vacuum advance connected or do you disconnect it. I am assuming you move only the distributor and leave everything else hooked up; am I correct?
        Kurt
        • Roy B.
          • February 1, 1975
          • 7044
          Re: Timing??? YES *NM*
          • Robert Willis
            Re: Timing???
            Well I kinda do it that way. I loosen the dist and then bring thr Rs up a little and advance the dist till I can feel a slight viberation at the carb ( kinda like feeling the viberation on your fender when useing the old on car wheel balancers) then back it off a whisker. The viberation at the carb has to be a little pre-ignition. I do all the old cars this way and they all run great. I started doing this in 1976 when I forgot my timing light for my drag car, and it ran the best it ever did.
            Bob
            283 cu in NHRA Stockers
            • Roy B.
              • February 1, 1975
              • 7044
              Re: Timing??? your old too *NM*
              • Robert Willis
                OLD ????
                • Philip C.
                  • December 1, 1984
                  • 1117
                  Yep thats all there is to it byeCrackie *NM*
                  • Allan J. Wicklund
                    Re: Yep thats all there is to it byeCrackie
                    Had to chime in! I've not used a timing light in about 43 years. High School shop teacher, Mr Kern made us use them. I like to let my ears tell me when to stop advancing timing. Al W.
                    • Mike M.
                      • May 31, 1974
                      • 8396
                      Re: Timing???
                      doubt toney stewart's, dale jr's or rainbow fairy's(#24) engine builders rely on their ears to time the nascar engine's timing.i'll stick with the trusty timing light(which is significantly more OBJECTIVE than the ears) to set timeing on my sbcs and bbcs(which have all been degree'd in to account for any possible rotation of outer sleeve on harmonic balancer). mike
                      • Roy B.
                        • February 1, 1975
                        • 7044
                        Re: Timing??? Mike
                        That's wonderfull! OK you do your thing but my thing works for me, I never said any one had to follow my thing and never would. I only say what I do!
                        • Mike M.
                          • May 31, 1974
                          • 8396
                          Re: Timing??? Mike
                          10/4 roy. glad you've had success with auditory timing. should have my 55 vette, also a copper dude(sans bubbletop) restored in a year or so. would you be interested in a Dipstick/ Mikie type drag race with your and my coppper beauties in the near future. promise i won't cheat. mikie
                          • Roy B.
                            • February 1, 1975
                            • 7044
                            Re: Timing??? Mike
                            I would love to drag with our cars, I wise you were not so far away,we would get along great, Best ROY
                            • Terry R.
                              • March 1, 2005
                              • 359
                              Re: Timing??? Mike
                              Two Copper '55s drag racing! Great cover picture for the Restorer. Terry Robertson
