Routing-59 Turn Signal Wires - NCRS Discussion Boards
  • Jeffrey C.
    • June 30, 1995
    • 53
    From the steering wheel center are the wires routed through the steering column with the horn wire or on the outside of the column under the painted cover. It seems like the wires would have the opportunity to get wrapped around the column when it turns with that many wires are routed inside...
  • Mark L.
    • January 1, 1996
    • 121
    Re: Routing-59 Turn Signal Wires
    The flat cable is in fact routed from the signal light switch through the column, keep it nice and straight and you should be all set. Best Regards, Mark
