Got dinged on my hood support at Marlborough because it doesn't have ATwood stamped on it. Does have the 16077 part number on it. I suppose I bought it from Chev around 79 to '81 but don't remember. Now I am studying the 63 hood support info. I have been getting bits and pieces of info. I understand that the last one that Chev sold would not be correct for a '63 to 65. The logo should be stamped on the engine side of the support and the part number on the RH fender side. The washer or washers should be blackened. So to do this you must remove a rivet and then re-rivet the part back together which is something I don't like to do for sure. I understand that the repro hood support may not be correct for a '63 and even if it is I would still want an original.
What are some of the other difference between the early and later midyear hood supports. Saw a repro at a show that had the Atwood stamped into the inner part of the channel. Did originals have Atwood stamped in various locations? Thanks, John
