67 Disc Brake Question - NCRS Discussion Boards
  • Mark K.
    • January 1, 1983
    • 148
    Just recently my 67 has been pulling hard to the right under heavy braking. My initial assumption was that there might be some air in the left front caliper that needed to be bled out, but unfortunately that is not the case. There were no air bubbles in the system and after bleeding I still have the same hard pulling to the right. The calipers were rebuilt with stainless inserts about 15 years ago and there are no system leaks. In reverse the car breaks fine.
    Is it possible that a left front caliper piston is binding? What other potential issues might I have?
    1967 L71 Silver/Black Coupe - Unrestored/Original Paint, Top Flight at 1998 Regional in Ontario, not judged since
    1995 Red/Red ZR-1 - Top Flight back in 2010 Michigan Chapter meet
  • Kent D.
    • February 1, 1992
    • 100
    Re: 67 Disc Brake Question
    Check your left front brake hose, it is most likely pluged up.
    • Wayne K.
      • December 1, 1999
      • 1030
      Mark,
      If the hoses are old you might have one that is collapsing.
      Wayne
