routing a rear wiring harness - NCRS Discussion Boards
  • nelson perez
    so today i attempted to install the rear wiring harness on my 64 convertible and was immediately stymied on how to get the harness through the grommet. i was able to get the antenna cable through but the rear harness with all of its connectors at both ends would seem to me to make it impossible to get through the rubber grommet. does anyone have a suggestion?
    • May 31, 1974
    • 8396
    Re: routing a rear wiring harness
    remove grommet which was originally transected. then slip harness thru transection and pop the grommet/harness back into the hole in the bulkhead. mike
    • Joe C.
      • August 31, 1999
      • 4598
      What The Doctor Means, Is Cut It In Half
      Well, not completely. You know what I mean, don't you? Cut thru its radius, not its diameter.
      Joe
      • Chuck S.
        • April 1, 1992
        • 4668
        Yeah...The Grommet...Not The Harness!
        Sounded like the Doc was talking about a bowel or something, eh, Joe?
        • Joe C.
          • August 31, 1999
          • 4598
          I Dunno,But I Did Stay At A Holiday Inn Last Nite
          OKAY, I'd like to buy a vowel. Sorry, did you say, bowel??
          I was thinking about a c-section, actually. Although, I understand that that's not as bad as a vivisection.
          Joe
