72 conv best way to remove antifreeze from carpet - NCRS Discussion Boards
  • Phil P.
    • April 1, 2006
    • 409
    r&r the heater core on my 72 as it leaked (non a/c)---purchased a new core and had the harrison end plates put on the new core as the replacement pipes are not configured to fit the blower housing---two things i found out while doing this---there are 2 inboard nuts top and bottom that are behind the blower housing that hold the core housing to the body---these are not shown in the aim---the next thing i found was that i could remove the heater core from the car through the firewall by shifting the core housing around to remove the clips,this will save about 1 to 2 hours of labor since you do not need to remove the radio an associated gear to get the housing out---well now to my question--the carpet is in excellent condition and short of removing it, is there a good suggestion on cleaning the antifreeze out of it---thanks to all respones
  • Mike E.
    • February 28, 1975
    • 5139
    Re: 72 conv best way to remove antifreeze from car
    Phil,
    Within the last 3-4 weeks on this board there was a significant thread about that very question. Try the archives, and I think we'll help you there.
    Good luck!
    Mike Ernst
    • Jim T.
      • March 1, 1993
      • 5351
      Two options to flush the coolant from the carpet. You have plastic plug in the floor that can be removed to drain flush water through the carpet/insulation or just remove the carpet and insulation and flush the coolant and have the advantage of it all drying with assistance from the sun.
        Dilution-the solution to pollution...
        I've gotten 'em clean by removing the passenger seat, pouring a 2-gal bucket of soap + water onto the cockpit floor, scrubbing gently and extracting with a wet/dry shop vac. Then, follow with 3-6 more exchanges of rinse water. Repeat as necessary until the carpet doesn't feel 'slippery' to hand touch. When done, set 'er out in direct sun and let air dry for a full day.
        • Harmon C.
          • August 31, 1994
          • 3228
          Re: Dilution-the solution to pollution...
          Jack
          I like your method and the one day to dry in Colorado. Here in Ohio that time to dry may take a week to get a couple days of sun to help out.
          Lyle
          Lyle
          • Phil P.
            • April 1, 2006
            • 409
            looks like a cleaning project for saturday---hate to leave it in the sunny hot so cal sun for a day of drying but i guess it's what i'll have to do---thanks to all for the info
            • Philip C.
              • December 1, 1984
              • 1117
              Get some newapapers to help dry
              Go down to your local C-store and ask them to save the unsold news papers for you. Lay a layer of paper on your clean but wet carpet, the paper will soak up the water, keep changing the paper, this helps to dry the carpet much quicker. Phil 8083
