1968 Early vs Late - NCRS Discussion Boards
1968 Early vs Late
  • Scott Bradley
    1968 Early vs Late
    Guys,
    I have a 1968 Convertible that I am going to try to restore to an origional state. I am wondering if it would have any of the Early parts on it.
    Sequence Number: 407246
    Body Date Code: C19
    If you have looked at the link, yes it does have a long way to go. Whole new font clip and rear clip. cosmetic work to the engine compartment. I have already sourced the wiper door assembly. It is turning out to be a fun project.
    Scott
    Origional Ebay Add
    • 15601
    Re: 1968 Early vs Late
    If your VIN is 194678S407246, the build date on the trim tag should be E20 -- December 20, 1967. I suggest you check these numbers again to be sure what you have.
    • Scott Bradley
      I will take a look, I probably read the date code number incorectly last night.
      • Steve Wallach
        Also it's common to confuse a "C" and a "G" on these tags.
        Mine is a Feb. 68 built car and has many "early" components and some "late" ...
        A late 67 built 68 would likely have early items.
        I agree with Terry, be sure of what you have before you get too far into it so you know all your options.
        Cheers,
        Steve
