c2 - 1967 Alternator brace and bracket 427 - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2134
    Are all the '67 Big Block alternators (not including L88) attached in the same way?
    What alternator attachment parts are still avail., if any?
    Tom Dingman
    4889
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
  • Tom D.
    • 2134
    67 Alternator bracket 427 Number in Archive
    GM #3882810 is the correct alternator bracket for your non-power steering application. This piece is still available from GM (in 2002) for a current list price of $49.51 US (in 2002). Joe Lucia posted this in 2002.
    Are there other parts to complete the attachment? I have nothing but the engine and the alternator...
    Tom Again
    4889
    Michigan Chapter
    Tom Dingman
      Re: 67 Alternator bracket 427 Number in Archive
      Tom -
      The upper adjusting brace is P/N 3882812; besides the cast lower bracket, all the other bits are nuts, bolts, and washers, and a P/N 3831946 spacer. See section L36, sheet A3 in the '67 assembly manual for the illustration.
        • 43221
        Tom------
        As John mentioned, the bracket and brace are about all you need for the alternator mounting besides fastners. Unfortunately, both the bracket that I previously mentioned and the brace that John mentions are now GM-discontinued. However, I believe that you can get both in reproduction (or, NOS) from sources like Dr. Rebuild , Paragon and others.
        For a P/S application, all of the mounting brackets, braces, etc. are completely different. So, if you ever intend on converting to p/s, the time to do it is now before you purchase the mounting pieces you need.
