57 270 HP Dual Quad Carb Aircleaner Wing Nuts - NCRS Discussion Boards
  • Lars A.
    • June 30, 2004
    • 28
    Does anyone know what the correct wing nuts for the Carburator Aircleaners should look like and where I can get them for my 1957 270HP Dual Quad?
    THX
    Lars
  • Paul Bowers
    Re: 57 270 HP Dual Quad Carb Aircleaner Wing Nuts
    lars
    there was a post about a week ago showing a adversting photo of the engine cpmpartment of a 57 2 fours and the air cleaners had acorn nuts on the cleaners
    paul
    • Joseph T.
      • April 30, 1976
      • 2074
      Paul
      I posted that early picture of the 56/57 engine as seen below that showed the acorn nuts.
      However..one might want to check the 57 AIM..and see what was shown there...as well.
      I had acorn nuts on my survivor 57 #4353 283/245.
      There is some adjustment in the carbs threaded rod..but as I recall..not much with the original very thick carb to air cleaner gasket..resulting in using the acorn nuts. Also..helps with hood clearance.
      Surely others on this board will have experience to comment from.
      Joe Trybulec
        I was never able to get a solid answer to that question when I had my '57 270, but maybe we can today; I THINK it's one of these three, but I don't know for sure. The assembly manual calls out P/N 3736162 for the '57 2x4 air cleaner wingnuts, but I don't have that drawing to determine its configuration.
        • Joseph T.
          • April 30, 1976
          • 2074
          Lars / Paul / John
          I checked my 57 AIM and it shows wing nut part # 3736162 as John pointed out.
          As I recall..there is at least a 4th design wing nut with a stamped concave wing which the AIM drawing reminded me of.. Maybe someone can comment further.
          Early photographed cars for promotional purposes point out interesting details..but like parts buck engines..not all the parts were production.
          Joe Trybulec
          • Roy B.
            • February 1, 1975
            • 7044
            center one
            • Roy B.
              • February 1, 1975
              • 7044
              Sorry I should have said center is "one" of the correct ones , depends who the supplier was (more then one is correct )
              • Lars A.
                • June 30, 2004
                • 28
                Thank you all! There seems to be more then one answer. I have checked the Corvette Restoration and Technical Guide by Noland Adams. He has a technical illustration for the correct wing nut 3736162 on page 165 and it looks like the middle one and one page 166 he has pictures of on e with the middle ones too. However there were another picture on page 166 with a completely different ones. It looks like a flat washer with indented wings on the side. This type was also listed on ebay yeasterday and the Seller claims to have them verified by NCRS Judges to be correct (I tried to leave the link in this message). Let me know if anyone has any of these two variations of wingnut for sale (the middle illustration above or the flat washer with indented wings on the side.
                Many THX
                Lars
                • Chris H.
                  • April 30, 1990
                  • 817
                  Hey, that is my picture! It is most likely not the right one since I bought it new from Paragon.
                  • Roy B.
                    • February 1, 1975
                    • 7044
                    Because of the rescease in the air cleaner being concaved I never saw a flat round washer type wing nut being used on any C1 , the edge would cut into the air cleaner material , but I've seen other design nuts like the middle one you showed ,
                    • Chris H.
                      • April 30, 1990
                      • 817
                      I should also say I found the center one turned onto a heater housing stud on the firewall. it was painted over black from some "restoration" many years before I bought the car. Looks like someone took it off the air cleaner and screwed it there while doing something and then forgotten. The left hand one was on the air cleaner when I bought the car. (62 340)
                      chris
