68 steering box..... - NCRS Discussion Boards
  • Terry F.
    • September 30, 1992
    • 2061
    This may have been discussed but in the 68 judging manual it mentions that the steering box should have an aluminum cover. I seem to recall my car having a cast iron cover. In my frequent visits to the junk yards over the years (none recently), I recall later cars having the aluminum covers?? I bet that is a mistake. Terry
  • Gene M.
    • April 1, 1985
    • 4232
    Re: 68 steering box.....
    Cast iron is correct original
      • 43221
      Terry-----
      The JG will need to be revised to be more clear on this point in future editions. 1968 Corvettes used a steering box with a cast iron cover, just like the one used for 63-67. For 1969, the cover changed to the aluminum version described in the JG. However, very early 1969's may have used the cast iron cover, too. I do know, though, that an original owner, known-original 1969 built in October, 1968 has the aluminum cover.
      • Steve Wallach
        My 68 box has a cast iron cap, but I'm not sure it is the original?
        What numbers should be cast / stamped into the cover?
        Steve
        • Dick W.
          • 10483
          Joe, that comment has been duly noted. We have been looking at that item.
          Dick Whittington
            • 43221
            Steve----
            The casting number "5666723" should be seen on the cover. Also, there should be the word "CHECK" and "LUBE" with arrows pointing to cover retaining screw holes.
            • Steve Wallach
              Hi Joe,
              Thanks, On the cap, I can clearly see (cast) 23 then more to the center 6723 and what appears to be 71 stamped into the cover.
              I do see the arrows and CHECK and LUBE.
              Thanks Again,
              Steve
