71 LT1 smog - NCRS Discussion Boards
71 LT1 smog
  • Vincent F.
    • August 31, 2006
    • 202
    71 LT1 smog
    Did all 71 cars come with smog system,I read cars in some areas did not require it
  • Drew P.
    • June 30, 1977
    • 180
    Re: 71 LT1 smog
    Hello Vincent,
    All the 1970, 1971 and 1972 LT-1's came with smog systems.
    Do you have a copy of the 1970-1972 judging manual?
    Drew Papsun
      Not quite true...
      In '71, ALL engine configurations were equipped with CEC (Combined Emissions Control system, the carb idle solenoid and its relays), and the VRS (Vapor Recovery System, charcoal cannister). But, the AIR (Air Injection Reactor, smog pump) was NOT installed on base engine SB cars nor on LS5 BB engines...
      • Drew P.
        • June 30, 1977
        • 180
        Re: Not quite true...
        Hello Jack,
        You are correct for the base and big block. Vincent asked about his 1971 LT-1 engine in his Corvette did came smog system.
        Drew Papsun
          • 15674
          There's no such thing as a "smog system". The Air Injection Reactor (AIR) system an other systems that Jack referred to are "emission control systems".
          "Smog" is the result of photochemical reaction of emissions with sunlight in the atmophere.
          • Drew P.
            • June 30, 1977
            • 180
            Hello Duke,
            Thanks for the help.
            Drew Papsun
              • 43221
              Duke-----
              To be even more correct, AIR is an EXHAUST emissions control system. There are, of course, other emissions control systems on the car. The PCV system is a CRANKCASE emissions control system. EEC is a FUEL VAPOR emissions control system.
