71 LT1 I thought - NCRS Discussion Boards
71 LT1 I thought
  • Vincent F.
    • August 31, 2006
    • 202
    71 LT1 I thought
    I need to track the history of a car I think I got screwed on.The body,motor,trans,frame all have matching vin#,But there are things that don't jive.I think the body was changed to convert,and retagged with original vin tag.Is there a way to tell,also I think car had original title in Illonios,could I get info from DMV there or any other way to trace car?
  • Robert S.
    • July 31, 2004
    • 377
    Re: 71 LT1 I thought
    If I understand your post correctly you think you have a convert body with a coupe VIN...if it is a coupe VIN the first 5 digits will be 19437, if its a convertible they will be 19467. Hope this helps.
    Bob
    • Drew P.
      • June 30, 1977
      • 180
      Hello Vincent,
      Have you checked the following items. (1) The frame for the VIN Stamping? (2)
      The trim tag for date of build? (3)The driver door blue lable info? (4) The glass date codes? This is just a start to look at the whole car to understand what you bought.
      Drew Papsun
      • Vincent F.
        • August 31, 2006
        • 202
        Thanks yes all the dates are correct,no blue label on 71 doors,the buid date of car and moter are correct,frame has vin stamped on it,problem is car has auto trans hole cut in floor factory,No T.I.ignition
        • Chuck S.
          • April 1, 1992
          • 4668
          Converting a coupe to a convertible would be more trouble than it would be worth IMO, so I'm skeptical about such a conversion. The rear deck panel would have to modified (I don't know if this is even possible) or replaced; the rear plenum and drain system is totally different...to match the factory design in those areas would be a LOT of work.
          Remove enough of the interior trim panels to expose the body frame ("birdcage") where the halo support would be in a coupe. Examine the drawings of the birdcage in the AIM, UPC1...in the 70 AIM, the convertible lock pillar is shown on page A5, and the coupe lock pillar and side bow is shown on page A10. If a yokel sawed off that halo support, it's going to be a rough cut; not smooth sheared edges with a finishing cap (Item 7).
          The NCRS 1968-1982 Corvette Specifications Guide does not mention TI on ANY 71 engines, but spells it out on several 70 engines (L46, LT1, LS5)...I'm thinking it didn't exist on 71s, BWDIK.
          • Vincent F.
            • August 31, 2006
            • 202
            Thanks chuck,I have seen some 71LT1's with T.I.ignition.
            • Mike E.
              • February 28, 1975
              • 5138
              In 71, LT-1 cars came with TI.
              • Chuck S.
                • April 1, 1992
                • 4668
                Re: 71 LT1 I thought...More on TI
                Oops...Checked the judging manual...In 71, TI on LT1 and LS6. If the TI is just missing, there should still be some mounting holes in the driver-side behind the grill.
                • Anthony F.
                  • December 1, 1985
                  • 191
                  • Vincent F.
                    • August 31, 2006
                    • 202
                    thanks tony,will do
                      One alternative people often overlook in tracing their car's ownership history is hiring a private eye. The vehicle data bases of some states are closed to the public (privacy legislation), but open to law enforcement officials. Since most states require PI's to be registered/licensed, they often qualify for data access priviledges akin to bona fide cop shops.
                      The typical PI sees business cycles and sets his 'rack rate' based on peak demand. But, you can often get a 'deal' by shopping their services on a 'time available' basis meaning they work your case when there's nothing 'hot' in the job jar...
                      • Vincent F.
                        • August 31, 2006
                        • 202
                        Thanks Jack,great idea,I have tons off money into this car,need documentation
