Tires - NCRS Discussion Boards
Tires
  • Rex T.
    • December 1, 1984
    • 455
    Tires
    Anyone familiar with a Michelin "Destiny" tire? What are your thoughts about a 215 X 65 X R15 for a mid year Vette?
    Rex
  • Philip C.
    • December 1, 1984
    • 1117
    Re: Tires I wouldnt go bigger
    than 205 on a mid year Rex the front tire to fender lip gets real close when turning into a driveway and the suspension is depressing. Phil 8063
    • James W.
      • December 1, 1990
      • 2657
      Re: Tires
      Rex,
      I have no info on the "Destiny" tire, but I have the Michelin Harmony 205/75-15 blackwall tires on my '64 and they are fantastic.
      James West
      • Rex T.
        • December 1, 1984
        • 455
        Re: Tires
        Thanks James. I have learned that the two tires are the same, just a different name for marketing purposes. Can you tell me how tall your tires are?
        Rex
        • James W.
          • December 1, 1990
          • 2657
          Re: Tires
          Rex,
          Per the Tire Rack's tire specifications chart the Michelin Harmony's tire height is 26.9 inches tall. The rest of the specs for the tire are listed below. Log onto www.tirerack.com to see all the 205/75-15 tires they have to offer.
          Size = 205/75 SR15
          Max Load = 1598 lbs.
          Max. Inflation Press.= 35 psi
          Tread Depth = 11/32"
          Tire Weight = 25 lbs.
          Rim Width Range = 5-7"
          Meas. Rim Width = 5.5"
          Sect. Width = 8"
          Tread Width = NA
          Overall Diam. = 26.9"
          Revs Per Mile = 773
          Best Regards,
          James West
