69 Amp Gauge - NCRS Discussion Boards
69 Amp Gauge
  • Thomas Christopher
    69 Amp Gauge
    My Amp Gauge reads on the line between the 0 and -40 amps when my headlights are turned on. Is this normal, or is my Alt. going south?
    Thanks in Advance.
    Tom 69 350/350 4 Speed Roadster.
    • 43241
    Re: 69 Amp Gauge
    Tom----
    With the headlights on your amp gauge might be expected to read a needle width, or so, on the discharge (negative) side of "0". If your gauge is reading at the hash mark between "0" and "-40", I would say that you have some sort of a problem. An alternator output test would be a good place to start looking.
      Thanks Joe
      Thanks Joe. I'll check it out.
      Tom
