From the various Corvette catalogs, I gather that the relective Tonawanda #1 Team decal on the right hand valve cover did not come about until Corvette MY 1967. Is this correct? Also, the engine code for the 1966 Corvette with 427 cid/ 390hp version without AIR (K19) and with 4spd shows up as IL in the Spec Guide. Should there be a "IL" decal(s) on the rear of the valve cover as well as this code stamped on the engine block pad? Which valve cover should the "IL" be placed on?
1966 427 valve cover decals
Re: 1966 427 valve cover decals
Tony----
The Tonawanda valve cover decals first appeared for the 1967 model year for all Chevrolet models with Tonawanda produced engines. However, I suppose that it is possible that some very late 1966 models might have had them. Once-upon-a-time I was the original owner of a mid year built 1966 Chevelle SS396 L-34 and a 1968 Chevelle SS396 L-78. The 66 did not have the Tonawanda label, but the 68 did. This label was only placed on the right side valve cover.
A 1966 Corvette with L-36 engine, manual trans, and without A.I.R.(K-19) should have an "IL" suffix code on the engine pad. Originally, there was also an "IL" label affixed to the right rear valve cover surface. This was a paper label that was intended for plant personnel to quickly identify the engine to be pulled from the engine bay at St. Louis for installation in a particular Corvette. The labels were never designed or intended to last longer than this requirement dictated but some did.In Appreciation of John Hinckley- Top
