shifter lube - NCRS Discussion Boards
shifter lube
  • Albert P.
    • April 1, 2006
    • 205
    shifter lube
    I'm rebuilding my '64 shifter; what is the best lubrication to use when reassembling?
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: shifter lube
    White Lithium is my choice.
    • Albert P.
      • April 1, 2006
      • 205
      Thanks for the info *NM*
      • Alan Drake
        Re: Thanks for the info
        Garth,
        Doing the same with my 64. Have you found any reference to specifictions of how much space there sould be between the shifter levers in the main body, pn 3857393. The part which the shifter is bolted to. I now have .036 total spacing.
        • Wayne K.
          • December 1, 1999
          • 1030
          I like using Wurth HHS-2000. Great stuff. *NM*
          • Albert P.
            • April 1, 2006
            • 205
            shifter rebuild
            I'm not at that point yet; I'm just getting all the parts/supplies ready for when I take the shifter apart.
            • Jim T.
              • March 1, 1993
              • 5351
              Re: shifter lube
              I have used moly chassis lube, the same thing I used for the ball joints and tie rod ends. It has been a long time since I cleaned and relubricated my 68's 4-speed shifter and it still shifts easily after all these years. I will use it again when I clean it.
